ioxclient could not run on Win10
Zi Wei Fan
Hi expert,
After downloading the ioxclient_1.2.1.0_windows_amd64 for Windows 10 and click for running, the client always quickly quit in 1 second.
My OS & ioxclient version are as below. Could you please help to troubleshoot for this quit? Greatly appreciate!
Steve Zhang
Hi Zi Wei,
Please open a "Command Prompt" window and type "ioxclient.exe" to run it instead of clicking it directly in the Windows Explorer by mouse.
Steve
Thanks so much Steve!
After running the cmd as 'administrator' and typing 'ioxclient,exe', the status is as below and the command needs to be typed like example: 'ioxclient app status'.I could upgrade/upload/.. python programs after connecting my PC & IR829, if through local method.
Is it correct? Thanks again Steve!
Ziwei
For how to use ioxclient, please refer to https://developer.cisco.com/site/iox/documents/developer-guide/?ref=quickstart (Go to Getting Started --> IOx Client) for details.
