IR 809 and USB STORAGE
gkujawsk
Level 4
Level 4
Hi guys,
IR 809 fails to boot properly if the USB storage is inserted during power up.
Boot stucks in rommon-1> and there's no way to make it run. I tried to boot
HV from the usb drive but this failed as well. If I try to dir there are some error
messages. Take a look below.
I planned to use externally connected storage with my python app. Is it at all
possible? If I insert pen drive when the GOS is up and running there's no message
in dmesg at all. I use latest IOS and GOS available on cco.
IR809 Loader Stage 1 Version 1.6
FPGA version 0x20300 built 2015-12-16
Booted from the upgrade FPGA; SecureBoot did not fallback
Reset reason: CPU reset
BIOS Platform: IR800
BIOS Version: 10
SecureBoot core version: F01047X15.01ada48ab2015-04-03
Microloader version: MA0061R06.0404022015
Booted from the upgrade BIOS
Autoboot is ON, variable: bootstrap:ir800-hv.srp.SPA.0.37
ERROR: autoboot image not valid, autoboot suspended
rommon-1> dir
mount: /dev/flash: failed to setup loop device: No such file or directory
mount: /dev/bootstrap: failed to setup loop device: No such file or directory
flash:
bootstrap:
usb:
          575 Jul  8 18:36 MANIFEST
     24447317 Jul  8 18:36 ir800-hv.srp.SPA.0.37
     87535926 Jul  8 18:36 ir800-ref-gos.img.2.3.gz
     62346519 Jul  8 18:36 ir800-universalk9-mz.SPA.156-2.T1
rommon-1>
gkujawsk
Level 4
Level 4
I've just format the usb storage with ext2. rommon-1 fails to mount it
but at least shows that it was recognized by system as /dev/sda1... I assume that
rommon-1 expects internal flash at /dev/sda1 and plugged in usb storage
somehow overrides the defaults...
Any suggestions?
rommon-1> dir
mount: wrong fs type, bad option, bad superblock on /dev/sda1,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
       dmesg | tail or so.
flash:
bootstrap:
You may run the below command to boot SRP and IOS manually. Hope it helps.
//boot SRP:
rommon-1> boot flash:ir800-hv.srp.SPA.0.37
//boot IOS:
rommon-2> boot flash:ir800-universalk9-mz.SPA.156-2.T1
Steve
No I cannot. As I wrote flash: and bootstrap: are not available (empty)
if the box is boot up with usb pen drive plugged in. If pen drive is FAT32, then dir
lists its content. In this state I've tried to boot up the HV directly from the usb:
then over tftp, then over http. I've tried to change BOOTUP variables to boot
the IOS image from usb:, over tftp and over http. Everything failed. HV starts the
bootup processes, hangs on "Loading subjects" and after a couple of minutes
it's back to rommon-1>
If I remove the pen drive from the usb port ir 809 boots properly without any issues.
Thus my logical conclusion, that rommon-1 has some issues with USB drive.
The USB port was supposed to be available in GOS, but it's not. Plugging in any device
into usb port while ir 809 is running shows no messages in dmesg listing at all.
I've found somewhere on the Internet, that GOS will detect the usb storage only
if it was plugged in before the box boot up. However, I box do not boot up at all
when the usb storage is plugged in....
What's the proper way to connect USB storage to GOS?
PS. HV image is on bootstrap: and not on flash: drive.
