7841 phones with 4431 router - SIP SRST
Richard Simmons
Level 3
Level 3
Hi All,
Having an issue getting 7841 phones to register to a 4431 router in SRST, none of my phones register to the router when CUCM's are shutdown.
I have the following configuration;
voice service voip
ip address trusted list
ipv4 10.105.44.xxx
ipv4 10.105.44.xxx
rtp-port range 16384 32768
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class h323 1
h225 timeout tcp establish 5
voice register global
default mode <-- mode srst not available, only mode esrst or mode cme
no allow-hash-in-dn
timeouts interdigit 5
system message Phone is in emergency mode
max-dn 20
max-pool 40
voice register pool 1
translation-profile incoming SRST-IN
id network 10.0.0.0 mask 255.0.0.0
dtmf-relay rtp-nte
voice-class codec 1
any help would be greatly appreciated!
I found the fix for this, i hadn't populated the SIP address within the SRST reference on CUCM, once that was completed my original configuration started working.
5 Replies 5
Muhammad Awais Khan
My 7841 phones worked well with same configuration. I have two comments:
1) you  have to choose mode east which is obvious
2) for voice register pool 1
 Can you specify the specific subnet which exactly matches the IP Phone subnet, and you can create multiple pools instead of using one pool with big mask.
when you say chose mode east - is that auto correct from mode esrst ? is it not possible just to use standard srst ?
Sorry for that. Yes it is esrst :)
There is no option shown  for simple srst under voice register global
Great!! How we forget to talk about it :)
