8851 Kem
heamer
Dear Sir
i am new to 8851 ip phone , just need help for speed dial kem
i do program speed dial entries into the device and when the phone is turned off the entries are lost
is there is any advice why list is forgotten from the phone ?
thanks
First, are you using CUCM or CUCM Express? Also, can you explain what you mean by "when the phone is turned off"?
And do I understand correctly that you are programming speed dials directly on the phone rather than through CUCM/CUCME administration?
Maren
Thanks for your reply
currently I don't have cucm or any portal installed
I just entered the speed dial entries directly to the phone
The 8851 phones must connect to some kind of call-control system to work. Is the phone registered to CUCM? CUCM Express? Webex? A 3rd-party call control system like Asterisk?
Maren
