about CCM4.1.3 run DMA get Error
mr.marslin
I want upgarde to CUCM9.1 form CCM4.1.3.
First, I want upgrade to CUCM7.1.3 via DMA file.
But, I always get one error log file~
I cannot understand what is the wrong!!!
Have any recommand about it ?
Thanks.
Aman Soi
Hi Marslin,
Just a thought:
The error seems to be related to Informix Database S/w.
Can u first check the Database replication of Call manager 4.x? u need to have DBHelper.exe to check the status.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
regds,
aman
Aman Soi
Hi Marslin,
Just a thought:
regds,
aman
Because my lab is P2V.
maybe system have some issue.
I will try it @ single server.
Thanks.
Hi there,
One other note here is that the OS needs to be @ 2000.4.6
for this to be successful
CSCte01723    Upgrade Assistant should show higher min OS for upgrade to 7.1(3)
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCte01723
To  upgrade to 7.1(3), the Upgrade Assistant says that 2000.4.2 is  the  minimum required version. Using that OS Version, DMA can still fail   with a message like this: Failed to connect to datasource:.
Upgrade the Windows OS of all nodes in the cluster to at least 2000.4.6.
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
