Hi all, I working on a document that explain what is available when my publisher is down, and when I am only running on my subscriber (both of the servers have the same services activated, and it is CUCM 7.1.5 version).
From the SRND 7.X we can find that the user-facing feature are still available :
• Call Forward All (CFA)
• Message Waiting Indication (MWI)
• Privacy Enable/Disable
• Do Not Disturb (DND) Enable/Disable
• Extension Mobility Login (EM)
• Monitor (for future use; currently no updates at the user level)
• Hunt Group Logout
• Device Mobility
• CTI Certificate Authority Proxy Function (CAPF) status for end users and application users
• Credential hacking and authentication
But I would like someone to confirm that the following are also available :
- BLF/Speeddial configured on the phone (normally yes?)
- CCM User web interface (normally yes?)
- Web Directory (normally yes?)
- CUEAC Attendant Console ?
- RTMT Client (normally yes?)
Some other important service I may have forgotten ?
Thanks a lot for your help,
Thomas
