BE7M-M4-K9 Smartnet Total Care
a.wei
Hi Team,
I am trying to configure a BE7M-M4-K9 in CCW estimates and I am not able to see any SMARTnet total care options except for 3 years. Is this a BUG? I would like to configure 5 years. Plus, why is there an ECMU option??
6 Replies 6
Rajkumar Yadav
Level 4
Level 4
ECMU is replacement for UCSS and ESW which is actually software Smartnet.
Raaj
The issue in CCW is fixed now, Please go ahead retrieve the CCW quote again, and you shall see the desired service level in the selection. We apologize for the inconvenience.
Fei-Fei
Hi Fei-Fei,
Its still not showing Unfortunately. Do I need to rebuild the config?
atawade
Further to what my team member replied.
I double checked, the " Smart Net Total Care" option is reflecting in CCW.
For SNTC, in CCW
Add product --> “Select Service/Subscription”(bottom of SKU) -> Select “+” on “Smart Net Total Care” -> Select radio button on any of the service. This will give you an option of 1-60 months. You can add appropriately.
Hope this Helps…. Let us know if you require further help
Hi Team,
the issue is that the SNTC skus are not on the choices, please refer to screenshot on above comment.
atawade
Looks like your CCO ID access might be an issue. Can you open a Case thru My Work Space ?
https://www.cisco.com/cisco/psn/web/workspace
Basically just click on "?" on the Top Right corner in CCW and select "Open a Case"
put the relevant details and problem statement.
Give us the case number to track.
Note: you email is bouncing back, you may contact me on atawade@cisco.com
