call forward
balaji.babu1
Dear team,
we have requirement as below,
 customer will call to one toll free number and call will hit cucm via gateway and 7 am to  4 pm calls will be routed to agents and the requirement is from 5 pm to 10 pm the call should be forward/ routed to another toll free number .
is it achievable  through cucm ? we can forward the calls from unity auto attended or from any registered phone call forward option . any option other than this ? please support
regards
bala
Chris Deren
Yes, there are few ways to achieve it.
First of all when you say calls are routed to agents during business hours, do you have contact center solution i..e UCCX? If so then the easiest way would be to do the time of day check there.
If you do not, then CUCM does have time of day routing capabilities with time periods, time schedules that get assigned to partitions.  So, you could create a time period for 5-10PM, assign it to time schedule, built new partition and assign the schedule there.  Then you can build a CTI Route point with a DN that matches the number of your normal day number already in use, but assign it to the new partition.  Lastly, you need to ensure this partition is listed above the other partition (normal routing) in every Calling Search Space that a call is initiated from, i.e. ingress GW/trunk, phones, etc.
