Cause i = 0x8081 - Unallocated/unassigned number
renji joy
Hi all,
The 3945 mgcp gateway connected with 1 PRI ,when ever customer calling incoming it's showing  Cause i = 0x8081 - Unallocated/unassigned number
some channels .the router connected with cisco contact center,please find attached debug isdn q931 debug
*Aug 27 10:06:08.642: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1200
                Sending Complete
                Bearer Capability i = 0x8090A3
                                Standard = CCITT
                                Transfer Capability = Speech
                                Transfer Mode = Circuit
                                Transfer Rate = 64 kbit/s
                Channel ID i = 0xA18384
                                Preferred, Channel 4
                Calling Party Number i = 0x2183, '775007658'
                                Plan:ISDN, Type:National
                Called Party Number i = 0xA1, '772222720'
*Aug 27 10:06:08.642: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9200
*Aug 27 10:06:08.950: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1100
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18385
                                Preferred, Channel 5
                Calling Party Number i = 0x2183, '774826473'
*Aug 27 10:06:08.950: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9100
*Aug 27 10:06:12.186: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x1000
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18387
                                Preferred, Channel 7
                Calling Party Number i = 0x2183, '771696189'
*Aug 27 10:06:12.190: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9000
*Aug 27 10:06:14.466: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0F00
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18388
                                Preferred, Channel 8
                Calling Party Number i = 0x2183, '778429121'
*Aug 27 10:06:14.470: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8F00
*Aug 27 10:06:15.242: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0E00
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18389
                                Preferred, Channel 9
                Calling Party Number i = 0x2183, '778118254'
*Aug 27 10:06:15.242: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8E00
*Aug 27 10:06:15.822: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0D00
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA1838A
                                Preferred, Channel 10
                Calling Party Number i = 0x2183, '770402109'
*Aug 27 10:06:15.822: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8D00
*Aug 27 10:06:18.998: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0C00
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA1838B
                                Preferred, Channel 11
                Calling Party Number i = 0x2183, '774957965'
*Aug 27 10:06:19.002: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8C00
*Aug 27 10:06:19.366: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0B00
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA1838C
                                Preferred, Channel 12
                Calling Party Number i = 0x2183, '774750461'
*Aug 27 10:06:19.370: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8B00
*Aug 27 10:06:22.410: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0A00
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA1838D
                                Preferred, Channel 13
                Calling Party Number i = 0x2183, '777575529'
*Aug 27 10:06:22.410: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8A00
*Aug 27 10:06:29.394: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0900
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA1838E
                                Preferred, Channel 14
*Aug 27 10:06:29.398: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8900
*Aug 27 10:06:30.406: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0800
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA1838F
                                Preferred, Channel 15
                Calling Party Number i = 0x2183, '771393512'
*Aug 27 10:06:30.410: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8800
*Aug 27 10:06:33.590: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0700
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18391
                                Preferred, Channel 17
*Aug 27 10:06:33.590: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8700
*Aug 27 10:06:33.790: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0600
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18392
                                Preferred, Channel 18
                Calling Party Number i = 0x2183, '779479047'
*Aug 27 10:06:33.790: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8600
*Aug 27 10:06:35.190: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0500
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18393
                                Preferred, Channel 19
                Calling Party Number i = 0x2183, '772019062'
*Aug 27 10:06:35.190: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8500
*Aug 27 10:06:38.394: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0400
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18394
                                Preferred, Channel 20
                Calling Party Number i = 0x2183, '771758630'
*Aug 27 10:06:38.394: ISDN Se0/2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8400
*Aug 27 10:06:39.470: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0300
                Sending Complete
                                Standard = CCITT
                Channel ID i = 0xA18395
                                Preferred, Channel 21
                Calling Party Number i = 0x2183, '772344587'
                Called Party Number i = 0xA1, '0772222720'
*Aug 27 10:06:39.474: ISDN Se0/2/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8300
                Channel ID i = 0xA98395
                                Exclusive, Channel 21
*Aug 27 10:06:39.486: ISDN Se0/2/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8300
                Progress Ind i = 0x8088 - In-band info or appropriate now available
*Aug 27 10:06:39.494: ISDN Se0/2/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8300
*Aug 27 10:06:39.586: ISDN Se0/2/0:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x0300
*Aug 27 10:06:43.554: ISDN Se0/2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0200
                Sending Complete
11 Replies 11
Joseph Martini
Make sure that the MGCP gateway configuration page in call manager contains a Calling Search Space under the inbound calls section that can reach the partition that 772222720 is in.  Also check the significant digits setting on the MGCP gateway page, to see if call manager is trying to look for the full number or just part of it.  Lastly if the settings look correct, try and reset the MGCP gateway from call manager and do a "no mgcp", "mgcp" on the router to update any configuration changes that may have been made.
Joe,
I had carefully verified all the settings several times, but our calls kept failing with the same 'Cause i = 0x8081'. I finally re-applied the swtich-type/protocol NI2 throughout (since I had been making some changes to troubleshoot), which did not get things working yet, but then just resetting mgcp as you indicated solved the issue
I'm glad I came across your post because it was driving me crazy.  Thank you!
i was also having this issue with incoming call, and did unnecessary troubleshooting like crazy.
Until i stumbled across this post to RESET the MGCP by doing a no mgcp, mgcp on the router.
I tried resetting mgcp gateway on the cucm, did not work. I had to do the reset on the voice gateway.
iS this a bug?
Ideally by resetting the gateway from cucm page the changes are pushed to the gateway. You can run "debug mgcp packets" to see what communication happens between gateway and cucm when it is reset from cucm. It could be something specific to your deployment.
Manish
Aaron Harrison
Your 'called' number inbound is appearing as 772222720 in all these calls. The error you have seen is telling you that you don't have that number allocated in your CUCM. This is either true, or it simply can't be reached from your gateway due to a problem with the CSS assigned to the E1.
You need to map this to a number by following these guidelines:
1) Firstly, the 'CAlling Search Space' on the E1/T1 config page in the 'Inbound' section must be set to one which includes the internal DN that calls need to reach, e.g. a CTI RP for Contact Center, a translation patter, or a simple DN on a phone etc. If you have an internal DN of 772222720 then this is all you need to do.
2) If not, then 772222720 needs to be mapped to the internal extension by some means. This is typically done is one of a few ways:
- Again on the E1/T1 page, in the 'Inbound' section, set a significant digits and/or prefix digits. For example, if you use four-digit extensions, and the intended place for this call to go is 2720, use sig digits = 4 to strip the rest. If your internal extension was 7720, you would use sig digits =3, and prefix 7. This assumes there is a logical correlation between the DDI number (772222720 and other numbers on this PRI) and internal extensions.
- If you have multiple number ranges on this PRI, and there is no correlation between DDI and extension (for example 772222720 maps to DN 1234) then you would need to add a translation pattern (in a partition in the CSS assigned to the PRI) to map 772222720 to 1234.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi all,
Right now one short number is there eg:779 (customer care number),Whenever customer calling this 779 nmuber the call
will coming this PRI .The telco 779 traffic mapped to the 772222720 this number ,Our 772222720 number transilated to the
779 trigger in callmanger.Also find attched sh runn configuration of router.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.08.27 15:39:40 =~=~=~=~=~=~=~=~=~=~=~=
sh runn
MTNA_VGW-1#sh running-config
Building configuration...
Current configuration : 4328 bytes
! Last configuration change at 05:17:24 UTC Thu Aug 25 2011
version 15.0
hostname MTNA_VGW-1
boot-start-marker
boot-end-marker
card type e1 0 1
card type e1 0 2
card type e1 0 3
no logging console
enable secret 5 $1$Vgzw$udUSIEf4sqOZc1DOW5.Y90
enable password cisco
no aaa new-model
--More--                           network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
no ipv6 cef
ip source-route
ip cef
isdn switch-type primary-net5
voice-card 0
--More--                           !
license udi pid C3900-SPE150/K9 sn FOC15060QW4
hw-module pvdm 0/0
username cisco
redundancy
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
controller E1 0/2/0
framing NO-CRC4
!ent
controller E1 0/2/1
--More--                            framing NO-CRC4
controller E1 0/3/0
framing NO-CRC4
controller E1 0/3/1
framing NO-CRC4
interface GigabitEthernet0/0
ip address 192.168.35.11 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
--More--                            duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation ppp
isdn incoming-voice voice
isdn bind-l3 ccm-manager
interface Serial0/2/0:15  (this the only  active Port)
no ip address
encapsulation ppp
isdn supp-service name calling
--More--                           !
interface Serial0/2/1:15
no ip address
encapsulation ppp
interface Serial0/3/0:15
no ip address
encapsulation ppp
interface Serial0/3/1:15
no ip address
encapsulation ppp
ip forward-protocol nd
--More--                           !
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.35.1
nls resp-timeout 1
cpd cr-id 1
snmp-server community UaOi4m5DbN4tB22kRO RO
control-plane
voice-port 0/1/0:15
echo-cancel coverage 64
voice-port 0/2/0:15
voice-port 0/3/0:15
--More--                           !
voice-port 0/2/1:15
voice-port 0/3/1:15
ccm-manager fallback-mgcp
ccm-manager redundant-host 192.168.39.50
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 192.168.35.50
ccm-manager config
mgcp
mgcp call-agent 192.168.35.50 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
--More--                           no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
dial-peer voice 1 pots
service mgcpapp
incoming called-number 0772222720
dial-peer voice 12 pots
service mgcpapp
incoming called-number 0772222721
--More--                           !
dial-peer voice 13 pots
service mgcpapp
incoming called-number 0772222722
dial-peer voice 14 pots
service mgcpapp
incoming called-number 0772222723
dial-peer voice 15 pots
service mgcpapp
incoming called-number 0772222724
dial-peer voice 16 pots
service mgcpapp
incoming called-number 0772222725
dial-peer voice 17 pots
service mgcpapp
incoming called-number 0772222726
dial-peer voice 18 pots
service mgcpapp
--More--                            incoming called-number 0772222727
dial-peer voice 19 pots
service mgcpapp
incoming called-number 0772222728
dial-peer voice 20 pots
service mgcpapp
incoming called-number 0772222729
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password cisco
login
--More--                           scheduler allocate 20000 1000
end
MTNA_VGW-1#
MTNA_VGW-1#
MTNA_VGW-1#
There's one catch, since you said the number is a trigger, that means it's going to contact center which does a redirect to a CTI port, the CSS that is used for the redirect is usually the problem, make sure that the original calling devices (CSS) gateway or if it is going through a translation pattern, the translation patterns CSS, contains the partition of the CTI port the call is redirected to.  More information on this can be found here:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCso91760
One addition, the redirect can be to a CTI port or agent DN, so check for both of those partitions in the original calling devices CSS.
Hi all
We are not using partition and css, Redircting to cti port
Regards'
If you aren't using partitions and CSSs (good practice says you should be) - then sig digits/prefix is the remaining important part.
Aaron
Hi Aaron,
Sorry i did'nt get you,  some calls are landing in IVR ,
