Change Unity Connection GUI Admin Password
Scott Hanson
Level 3
Level 3
Hello everyone,
CUC 8.6 in play.  I am finding a lot of information on resetting teh password if it has been lost but not a lot on just changing it.  Anyone have a link available?
Thanks in advance!  All replies rated.
Murali_DS
Refer the below link
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unity-connection/68400-unity-conn-password-recovery.html.
Hi ,
for CLI/OS administration ,
set password user admin  [Press enter now] .
admin is the username for login through OS.You need to enter your OS username .
for GUI access, check if this command  from CLI through putty
utils reset_application_ui_administrator_password
regds,
aman
Were you able to reset the password, if you don't have any more questions ,can u pls close this thread.
Hi ,
Thank you for this very helpful .
I have a question , if you want to have a same old password to unity gui pub ? would this possible
I have tied and it shows error as : 2018-01-11 23:08:54,717 ERROR [ClassExecutionThread] cli.cmdResetPasswd - Error:: 01/11/2018 23:08:54.714 : Update FAILED: code = 21, DUPLICATE CREDENTIAL
any idea , how I could get back to old PWD please
