03-11-2020 01:53 AM - edited 03-11-2020 02:00 AM
Hello guys, i have an ISR 4331 used as a voice GW for my legacy PBX interconnected with E1.
It performs random reboots through the day.
Here is the sh version and part of the crash info.
sh version Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Mon 17-Oct-16 20:23 by mcpre XXX uptime is 23 minutes Uptime for this control processor is 24 minutes System returned to ROM by reload System restarted at 08:06:36 UTC Wed Mar 11 2020 System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin" Last reload reason: Critical software exception, check bootflash:crashinfo_RP_00_00_20200311-080129-UTC ========= Start of Crashinfo Collection (08:01:29 UTC Wed Mar 11 2020) ========= For image: Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Mon 17-Oct-16 20:23 by mcpre Uptime = 00:51:41 ========= Exception Tracebacks ================================================= Exception to IOS: Frame pointer 0x7FA537784440, PC = 0x7FA5A540FCC2 IOS Thread backtrace: UNIX-EXT-SIGNAL: Segmentation fault(11), Process = TSP -Traceback= 1#00996a21ae914aca4b637c04ca379136 :7FA593FA7000+11468CC2 :7FA593FA7000+E4EF729 :7FA593FA7000+11C08703 :7FA593FA7000+11C093E7 :7FA593FA7000+E4FD44B :7FA593FA7000+E4FD0E7 Fastpath Thread backtrace: -Traceback= 1#00996a21ae914aca4b637c04ca379136 c:7FA55E0EA000+BDF12 Auxiliary Thread backtrace: -Traceback= 1#00996a21ae914aca4b637c04ca379136 pthread:7FA55833F000+A7C9
Is there anything that i can look for in my config to fix this issue?
Has anyone had anything similar?
03-11-2020 02:46 AM
Looks for me an IOS Bug, not able to find the bug number right one, try to upgrade latest stable recommended version as per the platform. before upgrading make sure you read the release notes and understand any known caveats.
03-11-2020 02:54 AM
It looks like bug. Can you please download carsh file from router and upload here.
03-11-2020 05:18 AM
Thank you for the response,
I will try with an upgrade, and inform you with the results.
07-18-2020 06:22 PM
We had the same thing happen to our 4331, was this resolved?
07-18-2020 11:37 PM
Actually i did not proceed to an upgrade of the ios or any other OS action.
Looking into the problem I realised that there were calls looping in from the E1 and out from the voip dial-peers several times.
It seems that this was causing the router to restart due to memory insufficiency.
We fixed the call routing of our connected PBXs as longs as the dial-peers of the routers and that seems to resolve the issue.
We haven't had a restart for several weeks now.
Hope this helps you too.
07-20-2020 09:15 AM - edited 07-20-2020 09:20 AM
Thanks, glad you got it fixed. I opened a case with Cisco TAC. They stated we are hitting this bug:
