Cisco 7800 Series Phones - CUCME Support
ATINC BAYTAN
Is there any document or information that you can share about CUCME support for new Cisco 7800 series phones? Is it supported at the moment, or when will it be committed to?
Thanks and regards
42 Replies 42
that is correct.
Yes it is in the roadmap to be supported in FY16
Mili
Hi Mili,
thanks for your feedback.
Regards.
Re: "Yes it is in the road map to be supported in FY16"
Is the 7821 SRTP support available yet, e.g., a  beta version?
not in the roadmap yet
csunni
What about the SRST feature with 7841 phones?. Does it requires 15.4-1 ?
Unni
78xx phone are supported with SRST 8.6 and above
thanks
Mili
I managed to get 7821's working with fast track approach, but found I had to remove call-feature-uri cfwdall command to be able to set call forward on the phone. Everything else appeared to work ok
can you give us brief about the configration
Below is the recommended config
New phone model
Recommended Fast-track config
7821
voice register pool-type  7821
xml-config maxNumCalls 6
xml-config busyTrigger 6
xml-config custom sshAccess 0
num-lines 2
description Cisco IP Phone 7821
reference-pooltype 6921
7841
voice register pool-type  7841
num-lines 4
description Cisco IP Phone 7841
reference-pooltype 6941
7861
voice register pool-type  7861
num-lines 16
description Cisco IP Phone 7861
reference-pooltype 6961
New phone model
7821
num-lines 2
7841
num-lines 4
7861
num-lines 16
Thanks Mili for this. I have it working with the only exception of not being able to get the firmware on to 10-1-1SR1-4, currently the phones are on the factory firmware of 10-1-1-9_REL. Don't suppose you have the config for this? I have followed Cisco examples for other SIP phones but the new firmware comes up failed on the phone when trying to upgrade and stays on the factory firmware. Thanks heaps.
Is there any possibility a recommended configuration could be posed for an 8831?
Right now , my CME IOS is 15.3.3(M) and CME 10.0 .. I have cisco 7841 SIP phones. I think i need to upgrade IOS to 15.4.1T ..Right?
7841 phone firmware also has to upload to flash ? or it will be there default ?
you need to uppgrade IOS to 15.4(3)M which is CME 10.5 and this release supports the 78xx phone series
Hi Mili
I still do not see anything on the Cisco website, datasheets, etc that confirms the 7800 Series SIP phones work with Call Manager Express (CME) Do you perhaps have a link? must prove to customer this is supported by Cisco then request the same from our lab.
Sure see here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/33matrix.html
Select 10 or even 10.5 as an example
Srini
