05-23-2018 12:06 AM - edited 03-17-2019 12:51 PM
Am getting a situation where all phones turn to unregistered after few mins from successfully registering. whenever i restart the switch or the phones does the same "successfully registering" few mins it gets back to Status "unregistered" and gets stuck at "Phone is registering"
its a new deployment, and we have a PUB and SUB.
Kindly need assist.
Thanks Regards,
05-23-2018 04:33 AM - edited 05-23-2018 04:34 AM
This problem could be caused by any number of things from the CPU pegging on your CUCM servers, to a network problem or PoE problem, to bad firmware. So let's get some information:
Let's start with that and see what we find.
Maren
05-28-2018 11:21 PM
HI Maren Mahoney.
Thanks for your feedback.
After investigating my network setup, found that there was a loop and that solve my issue.
Thanks once more!!
05-23-2018 05:23 AM
Get a parallel set of captures from the IP phone and CUCM to which it is registered ( from the point of registration till the time it unregisters ). This will help track the issue whether it is firewall related or something on the CUCM itself.
Manish
05-23-2018 05:30 AM
Hello, I am having a similar issue with CM 11.5.1.12900-21.
We have a large cluster of (4000+) 88x1 phones. We notice that phones that are not heavily used and remain idle for an undetermined length of time will suddenly become unregistered and require a power cycle to register. Most of the phones are in CDP. It is difficult for us to identify one that suddenly goes unregistered but we are trying. I opened a TAC case hoping this is a known issue.
Eddie
