Cluster UCM 8.5....
ooroncoym
I have a questions.....Is possible configure a cluster of Unified Communication Manager 8.5 with server UCS C210 M2 and MCS7845I3?
For example:
UCS C210 M2 :  PUB/SUB1 (Virtual servers)
MCS7845I3 : SUB2
Thanks for your help
5 Replies 5
jmunoz19
Level 4
Level 4
Yes, you can have a mix of virtual and physical servers, the software doesn't care.  What you propose is supported.
Is posssible configure a cluster of CUCM 8.5 with server UCS210M2 and MCS 7825 for only 1000 IP phone?
For example:
UCS 210M2 pub and MCS 7825 sub.
Yes, the answer above is not specific to the MCS7845 platform.  If you are using a supported virtual platform such as the UCS C210 then Cisco supports clustering of physical and virtual servers.  Generally, you should match VM specifications for CPU, memory, and disk space to physical server (in your case, 7825).
Hailey
Please rate helpful posts!
for encryption the calls on UCS i need KEY-CCM-ADMIN-K9 same for MCS?
Yes you need KEY-CCM-ADMIN-K9 regardless if  you are using UCS or MCS servers.
