CME-- Call manager SIP call is not working
renji joy
Hello Team,,
We are facing the issue with Cisco CME with call manager .
If we are trying the SIP trunk calls  from call manager not going to cme ,from cme to call manager sip call is connecting but there is no audio.
with the same setup H.323 calls going on both the way without any issue.
Configuration Done.
SIP trunk and route pattern configured and pointed to the CME ip addres..
Dial-peer has been configured in the cme router.
Any thing is missing and suggestion please...
69 Replies 69
Nadeem Ahmed
Do you have CUCM trace for calls not connecting from CUCM ----SIP TRUNK----CME and debugs logs CME------SIP TRUNK----CUCM.
CUCM to CME how they are connected? are they over WAN, VPN or LAN?
Can you please show run from CME? also check if you have applied the bind command on voice service voip or dial-peer level pointing to CUCM.
Br,
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
Hello ,
Thanks for the update
please find the attached sh runn for the cme..
Are you using these dial-peer for calling from CUCM to CME and vice-versa. In CUCM Cluster how many nodes are there? secondly can you make a test from both side and collect debugs and CUCM TRACES.
for Gateway Debugs run below debugs
1) debug ccsip messages
2) debug voice ccapi inout
from CUCM
enable detailed traces
dial-peer voice 3 voip
 description TEST
 preference 2
 destination-pattern 007........
 session target ipv4:172.16.5.100
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2 voip
 corlist outgoing localcalls
 description "Natoinal Mobile "
 preference 2
 codec g711ulaw
dial-peer voice 10 voip
 description "Moe HQ Dial-peer"
 preference 6
 destination-pattern 8...
 session transport udp
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
CUCM to CME connected over the VPN ,also tried to without VPN.
yes we are using the same dial-peer for calling.and there is two nodes in the cluster.
please note with the same setup H.323 calls going on both the way without any issue..
i will be sending the detailed logs for the reference.
To use SIP trunk between CME and CUCM, below are the recommendations:
1. From debug, CME received single digit from Phone and it looks like related to bug: CSCum05299.
Add below configuration and hard reset the phone:
                voice service voip
                no ip address trusted authenticate
2. Modify interface config:
#interface GigabitEthernet0/0.103
#no h323-gateway voip interface
#no h323-gateway voip bind srcaddr 172.18.3.129
3. In CUCM, SIP trunk destination IP address: 172.18.3.129 (GW voice vlan interface ip address)
4. In CUCM, make sure IP Phone and SIP trunk have same Device pool.
5. Modify dial-peer
#no dial-peer voice 10 voip
#dial-peer voice 10 voip
#description "Moe HQ Dial-peer"
#preference 6
#destination-pattern 8...
#session protocol sipv2
#session target ipv4:172.16.5.100
#incoming called-number .
#codec g711u
#no vad
Please test from SIP/SCCP phones, incoming/ outgoing calls and if any issue then share below information:
++ calling, called party number
++ enable 'debug voip ccapi inout', 'debug ccsip message', 'debug ccsip error'
PS: To avoid port/routing issue, test without VPN
Hi.
On your dialpeers you have to specify "protocol sipv2 " if you want to send or receive sip calls from/to CME
Please add it and let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
As mentioned by Carlo, you current dialpeers are using H323. To use SIP you need to apply the command 'session protocol sipv2' on each dialpeer. However, I don't think this is the only problem since this command is used for calls from CME. Calls to CME won't need this command.
Can you please do the following.
1. Start a call from CME to CUCM.
2. Share the output of 'debug ccsip messages' from the CME
3. Share the output of 'show voip rtp conn' from the CME
4. Share the output of 'show call active voice brief' from CME
5. Share the output of 'show sccp conn' from CME.
6. End the first call and try a call from CUCM to CME. Share the output of 'debug sip messages'
Hello Carlo,
if applying the session protocol sipv2 command call is not going from CME.
Also if selecting SIP trunk in the route pattern call is not going from call manger
sharing the outputs also..
We have registered one branch ip phone directly to the HO call manager for testing ,but the same issue call is not going from call manager /and from the branch office call is connecting but there is no audio
Please share the outputs which I requested to be able to assist.
As we mentioned earlier if applying the session protocol sipv2 command call is not going from CME.
Please find the
debg ccapi in out
u need inbound sip dial-peer too
Can you please give the example of sip dial peer
Configured the in bound dial-peer,can you please verify
dial-peer voice 4 voip
 description incoming
 codec g711ulaw
 no vad
