CP-8800-V-KEM= does it work with 8851?
Marc El Achkar
CP-8800-V-KEM= does it work with 8851? anyone tested it?
George Sotiropoulos
Yes it is applicable, check below:
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/ip-phone-8865-key-expansion-module/datasheet-c78-739845.html
G
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
hi,
in the datasheet they do not mention that it work with 8851, they mention 8865 compatibilioty
Rob Huffman
Hi Marc,
The CP-8800-V-KEM is not supported on the 8851/61's as they now use the CP-8800-A-KEM and the 8865's use only the V-KEM;
"This means that you cannot mix audio expansion modules with video expansion modules. You also cannot use a video expansion module on an audio phone or an audio expansion module on a video phone."
From;
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/7800-8800/english/accessories/p881_b_accessorie-guide-for-cisco-ip/p881_b_accessorie-guide-for-cisco-ip_chapter_01.pdf
You also see the distinction between the two module/models in this doc;
For 8865 deployments please consider the CP-8800-V-KEM=
For 8851/61 deployments please consider the CP-8800-A-KEM=
From;
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/eos-eol-notice-c51-741310.html
Cheers!
Rob
I wish I had noticed the difference in the SKU models for the different KEMs for 8851/8861 and the 8865 sooner. Now we have to return the CP-8800-V-KEM= and order CP-8800-A-KEM= for a client that has Cisco 8861 IP phone.
TK
