07-18-2016 07:52 PM - edited 03-17-2019 07:34 AM
It acts like its not getting any button presses. I don't know if there is something wrong with our DTMF relay or if it is a telco issue that they are not sending dtmf signals to our router. Below is some parts of the current config on our router:
voice rtp send-recv
voice service voip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
session transport tcp
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g723r53
codec preference 4 g723r63
codec preference 5 g729br8
interface ISM0/0
ip unnumbered GigabitEthernet0/1
service-module ip address 172.16.4.130 255.255.255.0
!Application: CUE Running on ISM
service-module ip default-gateway 172.16.4.1
control-plane
voice-port 0/1/0
trunk-group 4FXO
supervisory disconnect dualtone mid-call
connection plar 4100
description -- (072) 888-2085 -
voice-port 0/1/1
trunk-group 4FXO
shutdown
voice-port 0/1/2
trunk-group 4FXO
shutdown
voice-port 0/1/3
trunk-group 4FXO
shutdown
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 172.16.55.2 identifier 1 priority 1 version 6.0
sccp ccm 172.16.56.2 identifier 2 priority 2 version 6.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register reg1xcode
registration retries 15
registration timeout 8
keepalive retries 7
keepalive timeout 50
connect retries 5
connect interval 1200
switchback method graceful
switchback interval 120
dspfarm profile 1 transcode
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 10
associate application SCCP
dial-peer voice 4 pots
description ---To FXS Analog Phone---
destination-pattern 0113
dial-peer voice 5 voip
description --FXS to Manila PSTN--
destination-pattern *9[2-9]T
session target ipv4:172.16.55.2
dial-peer voice 7 voip
description --FXS to Reg2Tuguegarao PSTN--
destination-pattern *029T
session target ipv4:172.16.2.1
dial-peer voice 8 voip
description --FXS to Reg3Pampanga PSTN--
destination-pattern *039T
session target ipv4:172.16.3.1
dial-peer voice 9 voip
description --FXS to Reg5Pili PSTN--
destination-pattern *059T
session target ipv4:172.16.5.1
dial-peer voice 10 voip
description --FXS to Reg6Iloilo PSTN--
destination-pattern *069T
session target ipv4:172.16.6.1
dial-peer voice 11 voip
description --FXS to Reg7Cebu PSTN--
destination-pattern *079T
session target ipv4:172.16.7.1
dial-peer voice 12 voip
description --FXS to Reg8Tacloban PSTN--
destination-pattern *089T
session target ipv4:172.16.8.1
dial-peer voice 13 voip
description --FXS to Reg9aZamboanga PSTN--
destination-pattern *099T
session target ipv4:172.16.9.1
dial-peer voice 14 voip
description --FXS to Reg9bPagadian PSTN--
destination-pattern *049T
session target ipv4:172.16.9.129
dial-peer voice 15 voip
description --FXS to Reg10CDO PSTN--
destination-pattern *109T
session target ipv4:172.16.10.1
dial-peer voice 16 voip
description --FXS to Reg11Davao PSTN--
destination-pattern *119T
session target ipv4:172.16.11.1
dial-peer voice 17 voip
description --FXS to Reg12Koronadal PSTN--
destination-pattern *129T
session target ipv4:172.16.12.1
dial-peer voice 18 voip
description --FXS to Reg13Butuan PSTN--
destination-pattern *139T
session target ipv4:172.16.13.1
dial-peer voice 19 voip
description --FXS to Reg14Baguio PSTN--
destination-pattern *149T
session target ipv4:172.16.14.1
dial-peer voice 20 voip
description -- FXS to FXS --
destination-pattern [0-1]...
voice-class codec 1
ip qos dscp cs3 signaling
dial-peer voice 21 voip
description --FXS to IP Phone--
destination-pattern [2-5]...
dial-peer voice 22 pots
trunkgroup 4FXO
destination-pattern 9.......
forward-digits 7
dial-peer voice 23 pots
trunkgroup 4FXO
description --From Remote Site to Local PSTN--
destination-pattern *019T
forward-digits 7
dial-peer voice 51 voip
description ----- FXS to IP Phone -----
preference 2
session target ipv4:172.16.56.2
voice-class codec 1
dial-peer voice 52 voip
description ----FXS to Remote FXS ---
preference 2
voice-class codec 1
dial-peer voice 53 voip
preference 2
dial-peer voice 54 voip
description --FXS to Reg1Batac PSTN--
destination-pattern *610T
session target ipv4:172.16.28.1
dial-peer voice 7000 voip
description ***** Reg1 La Union AUTO ATTENDANT *****
destination-pattern 4100
session protocol sipv2
session target ipv4:172.16.4.130
incoming called-number 9T
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 201 voip
07-18-2016 08:35 PM
What is the call flow ? Does call comes inside from pstn using FXO ?
Try to use below dtmf relay in dial peer which is pointing to auto attendant.
dtmf-relay rtp-nte sip-notify
Suresh
07-18-2016 08:49 PM
when a customer tries to call our trunkline using either their landline or cellphone they will hear the auto attendant asking for a local number or if they don't know the local number they can dial 0 for our operator assistance. but even after they already pressed a digit multiple times the auto attendant will just say "are you still there?"
07-18-2016 09:00 PM
That's okay, I got that. But I'm asking call flow, you can describe as below.
mobile (pstn) -> fxo/pri -> voice gateway/cme -> cue.
Suresh
07-18-2016 11:30 PM
Hi. Sorry. yes call comes inside from pstn using fxo.
Already tried to use dtmf-relay rtp-nte sip-notify but still not working.
Thank you
