Expired Certs
Cleo Jamison
We have some self-signed certs that have expired. When I regenerate these certs will it require a restart of the Call Manager Server?
tomcat
PUBLISHER
Self-signed
RSA
PUBLISHER
PUBLISHER
02/01/2017
Self-signed certificate generated by system
tomcat-trust
PUBLISHER
Self-signed
RSA
PUBLISHER
PUBLISHER
02/01/2017
Trust Certificate
ipsec
PUBLISHER
Self-signed
RSA
PUBLISHER
PUBLISHER
02/01/2017
ipsec-trust
PUBLISHER
Self-signed
RSA
PUBLISHER
PUBLISHER
02/01/2017
Trust Certificate
CallManager
PUBLISHER
Self-signed
RSA
PUBLISHER
PUBLISHER
02/01/2017
CallManager-trust
PUBLISHER
Self-signed
RSA
PUBLISHER
PUBLISHER
02/01/2017
CallManager-trust
CAPF-ded3e58d
Self-signed
RSA
CAPF-ded3e58d
CAPF-ded3e58d
02/01/2017
Trust Certificate
CAPF-trust
CAPF-ded3e58d
Self-signed
RSA
CAPF-ded3e58d
CAPF-ded3e58d
02/01/2017
TVS
PUBLISHER
Self-signed
RSA
PUBLISHER
PUBLISHER
02/01/2017
CAPF
CAPF-09eb24e8
Self-signed
RSA
CAPF-09eb24e8
CAPF-09eb24e8
02/01/2017
CallManager-trust
CAPF-09eb24e8
Self-signed
RSA
CAPF-09eb24e8
CAPF-09eb24e8
02/01/2017
CAPF-trust
CAPF-09eb24e8
Self-signed
RSA
CAPF-09eb24e8
CAPF-09eb24e8
02/01/2017
tomcat-trust
SUBSCRIBER
Self-signed
RSA
SUBSCRIBER
SUBSCRIBER
02/01/2017
Trust Certificate
CallManager-trust
SUBSCRIBER
Self-signed
RSA
SUBSCRIBER
SUBSCRIBER
02/01/2017
CallManager-trust
CAPF-54253ad0
Self-signed
RSA
CAPF-54253ad0
CAPF-54253ad0
02/01/2017
Thanks for your reply.
2 Accepted Solutions
Jaime Valencia
Yes, when you re-generate the certificates (or replace them for CA signed), they will tell you what service(s) need to be restarted for the new cert to take effect.
Make sure to read the ITL documentation before doing this, to understand the proper procedure and avoid ITL issues.
java
if this helps, please rate
Jitender Bhandari
Hi Cleo,
Along with with Jaime said see below for better understanding.
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200199-CUCM-Certificate-Regeneration-Renewal-Pr.html
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/115957-high-level-view-ca-00.html
(Rate if it helps)
JB
Jaime Valencia
java
Jitender Bhandari
Hi Cleo,
(Rate if it helps)
JB
dohnesor
Anything with the -trust is basically a copy of a cert, either from another cluster or itself. They cannot be re-generated.
Anything without the -trust is local to the server i.e. the Private Key of the cert exists in the root access. Here is a summary of what needs to be restarted:
  • Tomcat - restart Tomcat service as well as TVS service
  • CallManager - restart CallManager, TFTP and TVS
  • CAPF - restart CAPF service
  • IPSEC - restart DRF Master and Local
  • TVS - restart TVS and TFTP
IMPORTANT: Always re-generate TVS service last or at least after re-generating CallManager certificate. When you re-generate CallManager the phones will not trust the new ITL file and will only refer to their cached ITL file. They will contact the TVS service over TLS and ask if the new CallManager certificate/ITL file can be trusted to which TVS will reply that it can. As you have not yet re-generated the TVS cert at that time, the phone trusts the TVS server as it's TLS fingerprint exists in it's cached ITL file.
Dennis Mink
Cleo, you would only need to restart the relevant services after you have uploaded the new certs, not the whole server.
check out this link if you are unsure:
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200199-CUCM-Certificate-Regeneration-Renewal-Pr.html#anc4
please rate if useful
Please remember to rate useful posts, by clicking on the stars below.
