External Call Control Profile
pusakills
I am trying to use the CURRI interface to  change the Calling Name of a caller.
the problem that I am facing is that CUCM doesn't connect to the application server.
in log: |AppInfo  |HttpManager - received routing req transactionID(16777229) for ECC profile [b26ca2f1-f7f2-6122-a3f0-ead0e3891d16], find handler in INACTIVE or with INVALID URI, send routing rej
I don't see any traffic going or coming to/from the http server...
any suggestions?
Br,
Marek
Hi Marek
Which version of CUCM are you running?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
10.5(2)
Please try to restart CM service and capture http logs through real time monitoring tool
Carlo
pusakills
The solution is here:
https://communities.cisco.com/message/190882
Br,
Marek
