h323 GW->CUBE->GW call no ringback
Hi all,
i have a cisco h323 gw with 2 fxs phones  connected to it. If a phone calls the othe using its internal number the call goes as expected, the terminating phone rings and the originating phone has its rinback tone.
If I call a phone using a global number, the call is routed through the cube. In this case the originating phone has no ringback.
On the gw  I had to configure for some reason the 'h225 h245-address on-connect'. With this command I can't have the ringback in-band (the gw receives open logical channel after the connect).
How can I force local ringback tone generation on the originating gw?
Is there any configuration I can make preferrably on the CUBE instead of the gw to accomplish this?
Thank you all,
Massimiliano
acampbell
Can you try adding
conf t
voice call send-alert
Retest
Alex
Regards, Alex. Please rate useful posts.
The running configuration of the h323 gw is:
voice rtp send-recv
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
h323
  h245 tunnel disable
  h245 caps mode restricted
dial-peer voice 1 pots
description Numerazione 911
destination-pattern 27911
no digit-strip
port 0/0/0
dial-peer voice 2 voip
destination-pattern .T
voice-class codec 1
session target ras
dtmf-relay h245-alphanumeric
dial-peer voice 3 pots
description Numerazione 922
destination-pattern 27922
no digit-strip
port 0/0/1
As you can see the 'voice call send-alert' command is already configured.
On a wireshark trace I take I can see an alerting go to the CUBE and then back to the gateway with the PI=8 (In-band information or an appropriate pattern is now available).
As per my understanding, the GW would expect the ringback tone from the terminating gw in-band. While I need the originating GW generating the ringback to the calling locally.
Massimiliano
Can you look at this link
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml#noringback
This might help.
Alex
