High number of "No. of inactive conn. ageouts"
Ali Amir
Hi All,
when I check the status of SIP connections I could see that I have a high number of "No. of inactive conn. ageouts". Base of documentations this value should be zero.
"Indicates the number of times that the connections were ended or timed out because of signaling inactivity. During call traffic, this number should be zero. If it is not zero, we recommend that the inactivity timer be tuned to optimize performance by using the timers command. "
Router#sh sip-ua connections tcp tls brief
Total active connections : 8
No. of send failures : 1
No. of remote closures : 491
No. of conn. failures : 2
No. of inactive conn. ageouts : 95
Max. tls send msg queue size of 1, recorded for 10.0.0.5:38701
TLS client handshake failures : 0
TLS server handshake failures : 1
-------------- SIP Transport Layer Listen Sockets ---------------
Conn-Id Local-Address
0 [0.0.0.0]:5061:
Could this cause any issue on my calls?
How can I analyze this in more details?
0 Replies 0
