How analog POTS dial-peer sets calling party for calls arriving
j.a.m.e.s
Level 3
Level 3
Could anyone advise me please, would a POTS dial-peer which receives an incoming call leg use it's destination-pattern to set the calling party (ANI) for that call?
dial-peer voice 100 pots
 description Lift01
 destination-pattern +44123456789$ <-- Will the lift have this CallerLineID if it places calls
 huntstop
 port 0/1/0
exit
I'm asking this because I need to setup a VG-400 gateway in SIP trunking mode (I normally leave this to MGCP/ccm-config, so haven't touched POTS in some time).
I could only find a vague reference to how IOS-XE handles this when a wildcard dial-pattern is matched.
On a VG you would set the calling name and number with these commands.
voice-port 0/1/0
station-id name Lift01
station-id number <number you want to present>
caller-id enable !not sure if this is required, from memory I don’t think we use it on our VGs normally, this is from an example on internet
Response Signature
No it would not use the destination pattern to set the ANI. The note you referenced is for a specific use case where there is no calling number.
Response Signature
voice-port 0/1/0
Response Signature
j.a.m.e.s
Level 3
Level 3
Thank you Roger, I will be testing this next week.
j.a.m.e.s
Level 3
Level 3
Just confirming that the station-id commands under voice-port are working in my tests.
