How to block IP communicator from registering in CME
Customer wants to block some users PC(IP Communicator)not to register in CME
5 Replies 5
Brandon Buffin
Disable auto registration and remove the ephone configured with their MAC address.
Brandon
If you can tell the command to disable the auto registration it is great help.
The commands are:
router#conf t
router(config)#telephony-service
router(config-telephony)#no auto assign
Hope this helps.
Brandon
Technically the phone will still register. It just won't get a DN. As well, you can specify multiple ranges so you would need to delete the specific range that has been defined.
The command you're looking for is:
telephony-service
no auto-reg-ephone
As said previously, make sure there isn't an ephone with the mac address defined. You'll need to delete that.
hth,
nick
Thanks.
