ā03-09-2017 11:17 PM - edited ā03-17-2019 09:46 AM
Hi All,
Can anyone shed some light on how to find out and delete unused DNs. not unassigned . Because there could be some virtual DNs used for some forwarding purpose.
Is there a way we could do this?
Any suggestions please...
ā03-09-2017 11:48 PM
Hi Ravi,
You can run a report under Call Routing > Route Plan Report to search for all Unassigned directory numbers and then delete them in one go from there.
Manish
ā03-10-2017 01:31 AM
Hi Manish,
Thanks for replying.
I have a requirement like this.
I have list of DNs not associated to any device to be deleted. In unassigned report, it will show up all DNs , even the ones actually being used as virtual DN for forwarding etc.
So is there any possibility like creating a custom file for the DNs I have and delete them in one shot.
Ravi
ā03-10-2017 01:34 AM
Hi Ravi,
You can use the following sql query to get a list of DN's with VM enabled
run sql select dnorpattern,cfadestination,cfavoicemailenabled from CallForwardDynamic c, numplan n where c.fknumplan = n.pkid and (cfadestination != '' or cfavoicemailenabled ='t')
Then you can compare that with the output from Route plan report and delete them.
Manish
