How to export ALL Ip phones data( MAC+Serial+DN+Description)in excel
tarek.shata
hi
i need to export ALL Ip phones data( MAC+Serial+DN+Description)in excel file
7 Replies 7
Jaime Valencia
I'll assume you mean in CUCM as you failed to provide that information, use BAT for everything but the SN, that information is nowhere in CUCM, so you would need 3rd party tools for that.
java
if this helps, please rate
As Java mention You can export that from BAT.
Using below SQL Query you can pull the phone Mac address, description, DN and Line CSS from CLI.
run sql select  device.name as DeviceMAC, device.description as enduser ,numplan.dnorpattern as Extension, callingsearchspace.name as CSS from device ,numplan , devicenumplanmap , callingsearchspace where devicenumplanmap.fkdevice =device.pkid and devicenumplanmap.fknumplan =nUMPLAN.pkid and numplan.fkcallingsearchspace_sharedlineappear= callingsearchspace.pkid and tkclass =1  order by callingsearchspace.name
For S/N you can use serial grabber, http://www.mediafire.com/?xs6se0b1i77d79s
Response Signature
tarek.shata
thank you all for your replay, but I need one action for all required, if there is a third party tool for required i think it will be good
What you need and what is natively possible in the system does not seem to line up here. Your options are to search for a 3:rd party option for this.
Response Signature
thanks Roger for reply
my question is: is there is any useful and safe tool to collect all required data
Serial
Mac
DN
Description
in just one action and export to excel or any extension
i already search with no match , if you know any safe tool i will be appreciated
I don’t. Not sure if there is any one tool available to get all the information. My personal recommendation is to go with what @Nithin Eluvathingal and @Jaime Valencia already suggested and get the information in two blocks and then combine them.
Response Signature
tarek.shata
thanks a lot, Roger Kallberg  for your recommendations
also thanks for  Nithin Eluvathingal  he is a great helper as usual
and thanks for Jaime Valencia
really appreciate your support
