04-18-2018 01:01 PM - edited 03-17-2019 12:39 PM
Good evening everyone,
I installed a TOIP network in a small company using a ISR Cisco 2901 (CME version 15.3) and IP phones Cisco CP-3905 . Among these IP phones, there is one that is damaged. I bought a new IP Phone Cisco CP-3905 and I want to replace the damaged one. then I want that the new phone to have the same phone number as the one that is damaged. I do not know the configuration (in command lines) to do .
could someone help me?
thank you in advance
04-18-2018 01:19 PM
Go to the ephone of the broken phone, reconfigure it with the MAC of the new phone, issue "create cnf-files" under telephony-service and plug in the new phone.
config t
ephone ##
mac-address <mac.of.new.phone>
exit
telephony-service
create cnf-files
end
wr mem
04-20-2018 06:39 AM
HI,
I tried this method but it does not work. see below
Router_VOIP#conf t
Router_VOIP(config)#ephone 1
Router_VOIP(config-ephone)#mac-address 00D0.D311.4AAD
ephone slot is already registered with 00D0.5808.0C83
Cannot change MAC address.
04-20-2018 07:48 AM - edited 04-20-2018 07:54 AM
The old phone is not plugged in when you do this, right? If not, unplug it. Then try the following:
ephone 1
reset
no mac-address
telephoney-service
create cnf-files
Then plug in the new phone.
If that doesn't work, you will need to remove the old phone and re-create it with the same config, but a different mac address.
First, unplug the old phone. Do not plug in the new phone.
Second, go into your router config and copy the entire configuration of ephone 1.
Paste that config into Notepad and replace (or add) the mac with the new one.
Back in your router, reset and then delete the existing ephone 1 with:
ephone 1
reset
no ephone 1
Then paste the config from Notepad (with the new mac) into your router.
Then, of course, issue 'create cnf-files' again.
I don't *think* this should cause any issues with CUE or with other components in your router as long as the config is exactly the same.
04-20-2018 10:54 AM
