ISR 4321 NIM2-FXS orange, unable to initialise or configure
4qbuddy
Hi all
Ive got a NIM2-FXS installed in a ISR4321. The card is showing orange lights and I cant enter any 'card' or 'voice' commands. The card appears in show inventory and service-engine0/1/0 is showing as up/up.
Am I missing some sort of licence command to unlock the ability to configure voice? I have 2 other routers set up in this way and don't recall having this issue before. Image is universalK9, 16.09.04, same as the others.
So far Ive:
- swapped the module slot
- swapped the card
- resat the card
I cant help but think its something very simple but I dont know what it is!
Thanks all
Leo Laohoo
What firmware is the router running and what license set is enabled?
Hi Leo
isr4300-mono-universalk9.16.06.04.SPA.pkg
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
Hard to see on a mobile, but from what I can tell you don’t have the UC license on the router.
Response Signature
@4qbuddy wrote:
uck9 None None None
No UC license enabled.
