Load ID CUCM Reporting
Leonardo Santana
Whats the diference between LoadID and ActiveLoadID in CUCM Reporting Unified CM Phones With Mismatched Load?
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Manish Gogna
Hi Leonardo,
As per my understanding the ActiveLoadID would be the firmware that is actually running on the IP phone , while the LoadID is the one defined on Device defaults or Phone Load Name setting on the phone config page. You can verify the same by analyzing LoadID and ActiveLoadID for one of the phones where they are not matching.
Manish
Manish Gogna
Hi Leonardo,
Manish
bvanbenschoten
Level 5
Level 5
Does anyone know for sure that if a phone has a load specified at the device level (different than the device defaults)  but the running code matches the device specified code, does it get flagged as a 'mis-matched load' ?
On phone page you should find active and inactive load if the phone firmware has been recently upgraded with the current available firmware on CUCM.
If you find active load only it means that the phone matches the leatest available firmware on CUCM or it has never been aligned due to a communication error with the TFTP
Carlo
Please rate all helpful posts "The more you help the more you learn"
