Migrating 5.1.2 to 5.1.3 (f)
a.gooding
Level 5
Level 5
Can anyone tell me what is the process to migrate CUCM 5.1.2 to 5.1.3 (f) ?
I currently only have CUCM 5.1.2 DVD and I need to apply an Upgrade patch to 5.1.3 (f). But when I try to use the Patch I get a message saying no
upgrade patch found in the folder.
Do I have to do a stepped upgrade cause I saw I can go straight to 5.1.3 (f) from that version.
Do I have to download a cop file or should the upgrade path work
Thanks in advance I got thrown on this at short notice and had no time to plan it out
Aman Soi
You can directly upgrade to 5.1.3f[ 5.1.3.7000-5]  from the 5.1.2.
No cop file is required.Make sure patch is lying in the correct path of sftp .
regds,
aman
