monitoring of the functional CME on the c2921
VolchanovAndrey
There is a task to monitor the performance of the functional CME on s2921. The criteria are as follows: The service is available (UP) service is not available (DOWN). Please tell me what snmp-server enable traps to use
Summary List of Notifications and Traps
Table 8     CISCO-CCME-MIB Summary List of Notifications and Traps
No.
Object Name
Comment
198
ccmeStatusChangeNotif
Notification generated if there is a change in ccmeEnabled
199
ccmeEphoneUnRegThresholdExceed
Notification generated when number of ephones registered is exceeded
200
ccmeEPhoneDeceased
Notification generated when registered ephone changes state to deceased
201
ccmeEPhoneRegFailed
Notification generated when an ephone attempts to register but fails
202
ccmeEphoneLoginFailed
Notification generated when an ephone user login is rejected/failed
203
ccmeNightServiceChangeNotif
Notification generated if night service status on this device changes
204
ccmeLivefeedMohFailedNotif
Notification generated when the MOH live feed fails
205
ccmeMaxConferenceNotif
Notification generated if the maximum number of simultaneous three-party conferences supported is exceeded
206
ccmeKeyEphoneRegChangeNotif
Notification generated if the key ephone registration status changes
Best Regards
Thanks for the answer!
At 2921 I write command snmp-server enable traps ccme.
If I get SNMP ccmeStatusChangeNotif then
it means the CME service does not work. If getting ccmeEPhoneDeceased
it means that phones are not registered. Do I understand correctly? What part of the phone should be registered that event would have worked ccmeStatusChangeNotif?
