Multiple authentication username in sip-ua CME
bagnolini
I've some problem with sip account with my CME (c2900-universalk9-mz.SPA.152-1.T.bin)
If I configure 1 single account per time everything is ok:
NUMBER1
sip-ua
credentials username 60510988031 password xxxxx realm voip2.voipvox.it
authentication username 60510988031 password xxxxx
no remote-party-id
disable-early-media 180
retry invite 2
retry response 3
retry bye 2
retry cancel 2
retry register 10
no timers hold
registrar 1 dns:voip2.voipvox.it expires 3600
sip-server ipv4:178.250.64.102:5060
cisco2901#show sip-ua register status
--------------------- Registrar-Index  1 ---------------------
Line                             peer       expires(sec) registered P-Associ-URI
60510988031                      -1         2850         yes
NUMBER 2
sip-ua
credentials username 60516951951 password xxxxx realm voip2.voipvox.it
authentication username 60516951951 password xxxx
no remote-party-id
retry invite 2
retry response 3
retry bye 2
retry cancel 2
retry register 10
no timers hold
60516951951                      -1         2872         yes
The problem is when I try to register both number (I must put the realm under at least one authentication username!!).
sip-ua
credentials username 60516951951 password xxxx realm voip2.voipvox.it
credentials username 60510988031 password yyyy realm voip2.voipvox.it
authentication username 60516951951 password xxxxx realm voip2.voipvox.it
authentication username 60510988031 password yyyyy
no remote-party-id
retry invite 2
retry response 3
retry bye 2
retry cancel 2
retry register 10
no timers hold
60510988031                      -1         2736         yes
60516951951                      -1         36           no
10 Replies 10
paolo bevilacqua
Create some voip DPs with destionation-pattern the number to register. Configure username and password in there. CME will register them using separate credentials. Then you will have a translation profile and rule to send the call to the right extension.
I created this dial-peer but the result is the same
dial-peer voice 14 voip
description Sip-0516951951
translation-profile outgoing PSTN_Outgoing2
destination-pattern 60516951951
session protocol sipv2
session target sip-server
session transport udp
dtmf-relay rtp-nte
codec g711alaw
authentication username 60516951951 password yyyyy realm voip2.voipvox.it
sip-ua
credentials username 60510988031 password xxxx realm voip2.voipvox.it
credentials username 60516951951 password yyyy realm voip2.voipvox.it
no remote-party-id
retry invite 2
retry response 3
retry bye 2
retry cancel 2
retry register 10
no timers hold
cisco2901#show sip register status
60510988031                      -1         862          yes
60516951951                      -1         159          no
Sorry, I meant a pots dial-peer. Associate to any port, it won't be used anyway. Then you can check with "debug ccsip message" that it triggers registration.
Thank you, now I'm able to register my account and make inbound call but I've some problem to make outgoing call.
I've attached the log about incoming and outgoing call.
This is my config:
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
modem passthrough nse codec g711alaw redundancy
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server
voice class uri 1 sip
pattern ^6051098xxxx
voice class uri 2 sip
pattern ^6051695yyyy
voice translation-rule 1
rule 2 /^32\([0,3,7-9]\)\(.*\)/ /032\1\2/
rule 3 /^33\([0,3-9]\)\(.*\)/ /033\1\2/
rule 4 /^34\([0,3,6-9]\)\(.*\)/ /034\1\2/
rule 6 /^36\([0,3,6,8]\)\(.*\)/ /036\1\2/
rule 8 /^38\([0,3,8,9]\)\(.*\)/ /038\1\2/
rule 9 /^39\([0-3]\)\(.*\)/ /039\1\2/
rule 15 /^\(\)/ /00\1/
voice translation-rule 2
rule 1 /^9\(.*\)/ /\1/
voice translation-rule 3
rule 1 /^.*/ /6051098xxxx/
voice translation-rule 4
rule 1 /^8\(.*\)/ /\1/
voice translation-rule 5
rule 1 /^.*/ /6051695yyyy/
voice translation-profile AddZero-Telecom
translate calling 1
voice translation-profile PSTN_Outgoing
translate calling 3
translate called 2
voice translation-profile PSTN_Outgoing2
translate calling 5
translate called 4
dial-peer voice 11 voip
description Chiamate in uscita verso Sip
destination-pattern 9T
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 12 voip
description Ingresso Numero 0510988xxx
translation-profile incoming AddZero-Telecom
session transport tcp
incoming uri request 1
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 13 voip
description Ingresso Numero 051695yyyy
incoming uri request 2
dtmf-relay rtp-nte
codec g711alaw
description Chiamate in uscita verso Sip-051695yyyy
destination-pattern 8T
no voice-class sip pass-thru headers
no voice-class sip pass-thru content unsupp
dtmf-relay rtp-nte
codec g711alaw
dial-peer voice 15 pots
destination-pattern 6051695xxxx
port 0/0/0
dial-peer voice 16 pots
destination-pattern 6051098yyyy
port 0/0/0
sip-ua
credentials username 6051098xxxx password xxxxxx realm voip2.voipvox.it
credentials username 6051695yyyy password yyyyyy realm voip2.voipvox.it
no remote-party-id
retry invite 2
retry response 3
retry bye 2
retry cancel 2
retry register 10
no timers hold
6051098xxxx                      16         301          yes
6051695yyyy                      15         301          yes
Take "debug ccsip message" and no other debug.
Post directly, no need to use attachments.
Please remember to rate useful posts clicking on the stars below.
OUTGOING CALL (FAIL)
Jan 18 12:24:15.497 CET: //6879/C83C76929E4E/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:3471526635@178.250.64.102:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.13:5060;branch=z9hG4bK97483
To: <3471526635>
Date: Wed, 18 Jan 2012 11:24:15 GMT
Call-ID: C9D601FE-40FD11E1-9E53D66A-796E8D54@192.168.0.13
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3359405714-1090327009-2655966826-2037288276
User-Agent: Cisco-SIPGateway/IOS-15.2(1)T,
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1326885855
Contact: <60510988031>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 319
v=0
o=CiscoSystemsSIP-GW-UserAgent 6859 411 IN IP4 192.168.0.13
s=SIP Call
c=IN IP4 192.168.0.13
t=0 0
m=audio 19762 RTP/AVP 8 100 101 19
a=rtpmap:8 PCMA/8000
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Jan 18 12:24:15.553 CET: //6879/C83C76929E4E/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.0.13:5060;branch=z9hG4bK97483;received=192.168.0.13
To: <3471526635>;tag=as6e65c6e9
CSeq: 101 INVITE
Server: Switch24
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces, timer
WWW-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="1e3d0223"
Content-Length: 0
Jan 18 12:24:15.557 CET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:3471526635@178.250.64.102:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
INCOMING CALL (OK)
Jan 18 12:25:42.785 CET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:60510988031@192.168.0.13:5060 SIP/2.0
Via: SIP/2.0/UDP 178.250.64.102:5060;branch=z9hG4bK1a149b4e;rport
Max-Forwards: 70
To: <60510988031>
Contact: <3409379407>
Call-ID: 45e4a34f50c989e571915ee620508033@178.250.64.102
CSeq: 102 INVITE
User-Agent: Switch24
Date: Wed, 18 Jan 2012 11:25:40 GMT
Content-Length: 298
v=0
o=root 35561604 35561604 IN IP4 178.250.64.102
s=Switch24
c=IN IP4 178.250.64.102
t=0 0
m=audio 18492 RTP/AVP 0 8 3 101
a=rtpmap:0 PCMU/8000
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Jan 18 12:25:42.801 CET: //6898/FDDD06379E70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <60510988031>
Date: Wed, 18 Jan 2012 11:25:42 GMT
CSeq: 102 INVITE
Server: Cisco-SIPGateway/IOS-15.2(1)T,
Content-Length: 0
Sent:
SIP/2.0 180 Ringing
To: <60510988031>;tag=38FF738-80E
CSeq: 102 INVITE
Content-Length: 0
Jan 18 12:25:43.041 CET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: <60510988031>
CSeq: 102 INVITE
Content-Length: 298
v=0
s=Switch24
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Jan 18 12:25:43.045 CET: //6898/FDDD06379E70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
Date: Wed, 18 Jan 2012 11:25:43 GMT
CSeq: 102 INVITE
Content-Length: 0
Jan 18 12:25:43.181 CET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
To: <60510988031>
CSeq: 102 INVITE
Content-Length: 298
v=0
s=Switch24
t=0 0
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
Jan 18 12:25:43.181 CET: //6898/FDDD06379E70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 102 INVITE
Content-Length: 0
Jan 18 12:25:44.557 CET: //6898/FDDD06379E70/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 9947 3995 IN IP4 192.168.0.13
s=SIP Call
t=0 0
m=audio 28252 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
Jan 18 12:25:44.609 CET: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:60510988031@192.168.0.13:5060 SIP/2.0
Via: SIP/2.0/UDP 178.250.64.102:5060;branch=z9hG4bK18f631cc;rport
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jan 18 12:25:45.965 CET: //6898/FDDD06379E70/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:3409379407@178.250.64.102:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.13:5060;branch=z9hG4bK98D06
To: "3409379407" <3409379407>;tag=as362d0249
Date: Wed, 18 Jan 2012 11:25:44 GMT
Max-Forwards: 70
Timestamp: 1326885945
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=54,OS=8640,PR=65,OR=10400,PL=0,JI=0,LA=0,DU=1
Content-Length: 0
You do not have configured authentication under sip-ua.
Please try to be more fair when rating, because I've 100% solved yuor problem above, but was rated only '4'.
I can configure only one authentication per-time under sip-ua, it works only one number!
If I try to configure the second number, it takes the place of first number.
sip-ua
credentials username 6051098xxx password xxxx realm voip2.voipvox.it
credentials username 6051695yyy password xxxx realm voip2.voipvox.it
authentication username 6051098xxx password xxxx
no remote-party-id
retry invite 2
retry response 3
retry bye 2
retry cancel 2
retry register 10
no timers hold
registrar 1 dns:voip2.voipvox.it expires 600
Correct. Already years ago I asked Cisco if there was any plan to support multiple authentication for outgoig calls, but their answer was not satisfying at all.
Eugene Zuevski
Have you resolved your issue with outgoing calls with multiple authentication?
