Need to login twice on 8945 handsets with extension mobility
rowdygardner
We are running CUCM 8.6 with 8945 handsets in extension mobility mode.
To set up a handset, we need to do the following:
1. Login as the userid and PIN on the handset via extension mobility
2. Login again as the userid and PIN to setup Personal Directory.
Is there a way to configure the system so that this an be done once, rather than twice?
i.e. Personal Directory automatically uses the Extension Mobility login and PIN.
Aaron Harrison
Hi Robert
Again, this goes to that process of setting up a one-button login for PAB. Obviously it works best if you don't changes PINs, as when you do the services need updating...
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
