Rebooting Subscriber in CUCM 7.1
I have to reboot a subscriber in CUCM 7.1 in order to run the disk recovery utility.
Will phones registered to the subscriber drop calls, and reload; or transparently reregister with the publisher?
Thanks in advance!
Shad
Rob Huffman
Hi Shad,
Active calls will be preserved IP Phones will re-register with the next
server listed in the Callamanager Group. In your case this sounds like the Pub.
Cheers!
Rob
Thanks Rob. Yep, there's only 1 sub.
Let's hope Cisco's recommendation - reboot & fsck - fixes the problem.
Incidentally, the issue is EXACTLY as described here:
http://web.archiveorange.com/archive/v/Ik6yqYIGoI9so4BcySld
in which the fix was to upgrade...
