01-09-2016 06:10 PM - edited 03-17-2019 05:27 AM
Customer is using Office 365 as an email server, and I cannot get the Email notification work:
Based on icrosoft, Server settings are as below:
Setting | IMAP (incoming) | SMTP (outgoing) |
Server Name | outlook.office365.com | smtp.office365.com |
Port Number | 993 | 587 |
Encryption Method | SSL | TLS |
CUCM server is able to ping outlook.office365.com and cmtp.office365.com ( means DNS has no issue)
And Also I have configured the below account:
RTMT_Admin@customerdomian.com
In the RTMT, email server configuration, I have added smtp.office365.com (port 587), did not work, then I added outlook.office365.com (port 993), did not work either, there is no document nor discussion around it on the net!, just wondering if someone has done it already?
HM
01-09-2016 10:31 PM
Do one thing, try to configure local SMTP relay server in your LAN using windows IIS. Then point your RTMT notifications to that server. This server can connect to O365. I got this configuration working.
I didn't manage to get direct notification to O365 and my MS Admin wasn't able to findout why
01-17-2016 06:49 PM
Hi Mohammad,
Thanks for your reply, basically there is no document on this over the net which is Odd!!
Anyway, What i did is on RTMT>config mail server add
mail server: ip address of the Relay server
Port:25
Account: RTMT_Admin@domain.com.au
And configured the Relay as per below document:
http://www.everonit.com/techtips/techtips/how-to-set-up-an-smtp-relay-for-use-with-office-365/
Is there any trick or missing point?
Hamed
01-17-2016 07:01 PM
Yes. This should do the job
01-17-2016 07:06 PM
I did packet capture and I can see that email comes to the relay, but apparently does not get to the office365.Need to check my Relay configuration.
Hamed
