04-12-2011 12:15 PM - edited 03-16-2019 04:28 AM
Is it possible to create a SIP trunk between CallManager v8.5.1 and v4.1 for 4 digit extension dialing between companies? Does anybody have any good writeup on how this is done or a pointer in the right direction?
Thanks!
Solved! Go to Solution.
04-12-2011 01:49 PM
Yes you can do that , it is easy , but since you are using two cisco clusters , it is easier and less using resources to use intercluster trunk.
Amer
04-12-2011 01:49 PM
Amer
04-12-2011 01:52 PM
Sorry,
FOrgot to add the link,
Here is a detail about tunks in call manager :
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/4_0_1/ccmsys/a08trnk.html
Amer
03-20-2014 06:27 AM
I have CUCM 8.6 on my site and I have a conection with another site through WAN, they have CUCM 9 and I wan to be able to transmit 4 digits and the caller id, can you help with the propers stept, how to etc.
Thanks a lot
03-20-2014 07:16 AM
Provided here:
https://supportforums.cisco.com/discussion/12146836/connection-between-cucm-86-and-9-through-wan#comment-9579636
