Hi all,
I'm looking for your help about a problem I'm experiencing on a customer site.
I configured a SIP Trunk with a "virtual" destination ip adress that load-balance to two "physical" ip adress (for a fax server cluster).
Since I do that, the outgoing fax does not work anymore, I get the following error :
"Unable to find a device handler for the request received on port 5060 from 10.243.14.2"
The reason I suppose is that the source IP adress of the INVITE SIP msg is not configured on the CUCM side (I only have in my trunk configuration the IP 10.243.14.4 -> the virtual ip adress).
How can I do to make it work properly, with the load balancing process ?
Thanks in advance for your help,
Thomas
