stream music to ip phone speaker
Is there a way to stream music to your ip phone speaker ?
5 Replies 5
Jaime Valencia
sorry, not possible. not the 1st time i've heard someone ask for this that some PBXs provide.
java
if this helps, please rate
java
I think its possible to stream audio, by using the URI in ip phone service, RTPRX for unicast and RTPMRX for multicast. I tried with unicast and its working allmost perfect. U have to stream the audio with g.711 u law.
Steps
1 - Create one IP Phone service in ur communication manager, with service url,
RTPMRx:239.1.1.1:16390:80
Where 239.1.1.1 matches your multicast ip address. 16390 is the port number of the stream .
And the :80 is optional, and is the volume %.
make sure u r streaming in g.711 ulaw.
Hope this helps.
Has anyone used the Barix device as an alternative MOH source?
Philip Hopkins
This definitely is possible now. You will need a Barix Instreamer. (converts audio into g.711 uLaw).
Please see their guide on how to integrate:
http://www.barix.com/fileadmin/data/howto/Instreamer-Cisco_application_note_v14.pdf
Hopkins17...thank you...it worked
