11-13-2017 12:25 PM - edited 03-17-2019 11:35 AM
I have a new task to upgrade my current UCS servers that host CUCM, CUC, UCCX, and Presence to the newest UCS servers because they have reached EOL/EOS with Cisco TAC. I understand that I will have to get with the licensing team once I am done so that I can rehost the licenses for all servers. I'm also not that worried about the subscribers as I can just install them fresh and have them replicate from the Publisher. However, I don't want this evolution to take a month to complete (a different story different time). If I do a DR backup off the old server then restore to the new server how will I handle the change of the MAC on the new publishers of each of these servers. Also, because of bad past experience attempting to use DR backups to restore from I don't really have a good feeling this will be successful. Can anyone offer a better solution?
Solved! Go to Solution.
11-13-2017 12:32 PM
Shutdown the VMs and move them to the new host, or if you have vCenter, shut them down, and vMotion them.
11-13-2017 12:32 PM
11-13-2017 12:37 PM
Don't have vCenter and have never moved a server only made a snap shot of a server in case I screwed something up. I'm assuming there is a way to make a copy on a VM without vCenter, move it off that host and onto another one. Is this what you are saying?
11-13-2017 12:38 PM
yes
11-13-2017 12:40 PM
thanks for the quick response, one more question. What happens to the change in the MAC's? The license MAC isn't a big deal I don't think but all the other MAC's change as well don't they?
