unable to dial international
dsutphin
unable to call international calls. Running CME 10 on 2921 router have PRI circuit
find call capture below. At&t says this is not there issue.
using # for inter-digit timeout
calling number 5864467604
caller number 80118128813990#
call capture:
008206: Mar 1 17:09:45.761: //62839/B9B65DF08291/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=62839
008207: Mar 1 17:09:45.761: //62886/B9B65DF08291/CCAPI/cc_api_call_feature:
   Feature Type=50, Interface=0x40977FA8, Call Id=62886
008208: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/cc_api_call_facility:
008209: Mar 1 17:09:45.785: //62886/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
008210: Mar 1 17:09:45.785: call_info mainst_callID:0xF5A6, peer_callID:0xF577, confID:0x874, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
008211: Mar 1 17:09:45.785: //62886/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
008212: Mar 1 17:09:45.785:   stream[0]: callid:0xF5A6, media_passthrough:0
008213: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/ccConferenceDestroy:
   Conference Id=0x874, Tag=0x0
008214: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/ccConferenceDestroy:
008215: Mar 1 17:09:45.785: confID:0x874; callEntry1 callID1:0xF577, type:6; callEntry2 callID2:0xF5A6, type:3
008216: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x874, Source Interface=0x3E9926D4, Source Call Id=62839,
   Destination Call Id=62886, Disposition=0x0, Tag=0x0
008217: Mar 1 17:09:45.785: //62886/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008218: Mar 1 17:09:45.785: cc_api_get_xcode_stream : 4982
008219: Mar 1 17:09:45.785: //62839/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008220: Mar 1 17:09:45.785: cc_api_get_xcode_stream : 4982
008221: Mar 1 17:09:45.785: //62886/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008222: Mar 1 17:09:45.785: cc_api_get_xcode_stream : 4982
008223: Mar 1 17:09:45.785: //62886/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008224: Mar 1 17:09:45.785: cc_api_get_xcode_stream : 4982
008225: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x874, Source Interface=0x40977FA8, Source Call Id=62886,
   Destination Call Id=62839, Disposition=0x0, Tag=0x0
008226: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/cc_generic_bridge_done:
008227: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/ccCallFacility:
   Call Id=62886
008228: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0xF577, gcid=B9B65DF0-DF3011E5-8291F44E-5E62F10, tag=0x0)
008229: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0xF5A6, gcid=B9B65DF0-DF3011E5-8291F44E-5E62F10, tag=0x0)
008230: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/ccConferenceCreate:
   Conference Id=0xFFFFFFFF, Call Id1=62839, Call Id2=62886, Tag=0x0
008231: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/cc_api_bridge_done:
   Conference Id=0x876, Source Interface=0x3E9926D4, Source Call Id=62839,
   Destination Call Id=62886, Disposition=0x0, Tag=0xFFFFFFFF
008232: Mar 1 17:09:45.785: //62886/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008233: Mar 1 17:09:45.785: cc_api_get_xcode_stream : 4982
008234: Mar 1 17:09:45.785: //62886/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008235: Mar 1 17:09:45.785: cc_api_get_xcode_stream : 4982
008236: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/cc_api_bridge_done:
   Conference Id=0x876, Source Interface=0x40977FA8, Source Call Id=62886,
008237: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/cc_generic_bridge_done:
008238: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x876, Destination Call Id=62886)
008239: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x876, Destination Call Id=62839)
008240: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/ccConferenceCreate:
008241: Mar 1 17:09:45.785: confID:0x876; callEntry1 callID1:0xF577, type:6; callEntry2 callID2:0xF5A6, type:3
008242: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/cc_api_caps_ind:
   Destination Interface=0x40977FA8, Destination Call Id=62886, Source Call Id=62839,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
008243: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
008244: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3E9926D4, Destination Call Id=62839, Source Call Id=62886,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
008245: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/cc_api_caps_ind:
008246: Mar 1 17:09:45.785: //62886/B9B65DF08291/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=43331)
008247: Mar 1 17:09:45.785: //62839/B9B65DF08291/CCAPI/cc_api_caps_ack:
008248: Mar 1 17:09:45.789: //62886/B9B65DF08291/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=62886
008249: Mar 1 17:09:45.789: //62839/B9B65DF08291/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x876, Call Id1=62839, Call Id2=62886
008250: Mar 1 17:09:45.789: //62839/B9B65DF08291/CCAPI/cc_api_voice_mode_event:
   Call Id=62839
008251: Mar 1 17:09:45.789: //62839/B9B65DF08291/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x3F2BFE78)
008252: Mar 1 17:10:02.912: //-1/2E5FCA3F803E/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=1604
   ----- ccCallInfo IE subfields -----
   cisco-ani=1604
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=80118128813990#
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
008253: Mar 1 17:10:02.912: //-1/2E5FCA3F803E/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x40977FA8, Call Info(
   Calling Number=1604,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=80118128813990#(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=40016, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=62895
008254: Mar 1 17:10:02.912: //-1/2E5FCA3F803E/CCAPI/ccCheckClipClir:
   In: Calling Number=1604(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
008255: Mar 1 17:10:02.912: //-1/2E5FCA3F803E/CCAPI/ccCheckClipClir:
   Out: Calling Number=1604(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
008256: Mar 1 17:10:02.912: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008257: Mar 1 17:10:02.912: :cc_get_feature_vsa malloc success
008258: Mar 1 17:10:02.912: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008259: Mar 1 17:10:02.912: cc_get_feature_vsa count is 6
008260: Mar 1 17:10:02.912: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008261: Mar 1 17:10:02.912: :FEATURE_VSA attributes are: feature_name:0,feature_time:567235496,feature_id:10085
008262: Mar 1 17:10:02.912: //62895/2E5FCA3F803E/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1604(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=80118128813990#(TON=Unknown, NPI=Unknown))
008263: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/cc_process_call_setup_ind:
   Event=0x3E5C7A48
008264: Mar 1 17:10:02.916: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 80118128813990#
008265: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/ccCallSetContext:
   Context=0x3F2BD328
008266: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 62895 with tag 40016 to app "_ManagedAppProcess_Default"
008267: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/ccCallSetupAck:
   Call Id=62895
008268: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
008269: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/ccCallReportDigits:
   (callID=0xF5AF, digit_event=0x0, enable=FALSE, consume=FALSE)
008270: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=62895
008271: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x40977FA8, callID=0xF5AF, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
008272: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x40977FA8, Call Id=62895
008273: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
008274: Mar 1 17:10:02.916: //62895/2E5FCA3F803E/CCAPI/ccCallProceeding:
008275: Mar 1 17:10:02.920: //62895/2E5FCA3F803E/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=220, Params=0x3F2AA448, Progress Indication=NULL(0)
008276: Mar 1 17:10:02.920: //62895/2E5FCA3F803E/CCAPI/ccCheckClipClir:
   In: Calling Number=5864467604(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
008277: Mar 1 17:10:02.920: //62895/2E5FCA3F803E/CCAPI/ccCheckClipClir:
   Out: Calling Number=5864467604(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
008278: Mar 1 17:10:02.920: //62895/2E5FCA3F803E/CCAPI/ccCallSetupRequest:
   Destination Pattern=8011T, Called Number=80118128813990, Digit Strip=TRUE
008279: Mar 1 17:10:02.920: //62895/2E5FCA3F803E/CCAPI/ccCallSetupRequest:
   Calling Number=5864467604(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=80118128813990(TON=Unknown, NPI=Unknown),
   Redirect Number=, Display Info=MacDormott, Tracy
   Account Number=1604, Final Destination Flag=FALSE,
   Guid=2E5FCA3F-DF31-11E5-803E-E9BB423D3151, Outgoing Dial-peer=220
008280: Mar 1 17:10:02.920: //62895/2E5FCA3F803E/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=1604
   cisco-ani=5864467604
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=80118128813990
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
008281: Mar 1 17:10:02.920: //62895/2E5FCA3F803E/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3E9926D4, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=5864467604,(Calling Name=MacDormott, Tracy)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=80118128813990(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE, Outgoing Dial-peer=220, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
008282: Mar 1 17:10:02.920: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008283: Mar 1 17:10:02.920: :cc_get_feature_vsa malloc success
008284: Mar 1 17:10:02.920: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008285: Mar 1 17:10:02.920: cc_get_feature_vsa count is 7
008286: Mar 1 17:10:02.920: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
008287: Mar 1 17:10:02.920: :FEATURE_VSA attributes are: feature_name:0,feature_time:567239752,feature_id:10086
008288: Mar 1 17:10:02.920: //62896/2E5FCA3F803E/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
008289: Mar 1 17:10:02.920: //62896/2E5FCA3F803E/CCAPI/ccCallSetContext:
   Context=0x3F2AA3F8
008290: Mar 1 17:10:02.920: //62895/2E5FCA3F803E/CCAPI/ccSaveDialpeerTag:
008291: Mar 1 17:10:02.924: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is 0x2 0x1, Calling num 5864467604
008292: Mar 1 17:10:02.924: ISDN Se0/0/0:23 Q931: Sending SETUP callref = 0x035A callID = 0x82DB switch = primary-ni interface = User
008293: Mar 1 17:10:02.924: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x035A
       Bearer Capability i = 0x8090A2
               Standard = CCITT
               Transfer Capability = Speech
               Transfer Mode = Circuit
               Transfer Rate = 64 kbit/s
       Channel ID i = 0xA98397
               Exclusive, Channel 23
       Facility i = 0x9F8B0100A11902013C02010080114D6163446F726D6F74742C205472616379
               Protocol Profile = Networking Extensions
               0xA11902013C02010080114D6163446F726D6F74742C205472616379
               Component = Invoke component
                       Invoke Id = 60
                       Operation = CallingName
                               Name Presentation Allowed Extended
                               Name = MacDormott, Tracy
       Calling Party Number i = 0x2181, '5864467604'
               Plan:ISDN, Type:National
       Called Party Number i = 0x80, '0118128813990' 8 has been stripped.
               Plan:Unknown, Type:Unknown
008294: Mar 1 17:10:03.024: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x835A
008295: Mar 1 17:10:03.024: //62896/2E5FCA3F803E/CCAPI/cc_api_call_proceeding:
   Interface=0x3E9926D4, Progress Indication=NULL(0)
008296: Mar 1 17:10:04.124: ISDN Se0/0/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x835A
       Cause i = 0x82FF - Interworking error; unspecified
       Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
008297: Mar 1 17:10:04.124: //62896/2E5FCA3F803E/CCAPI/cc_api_call_cut_progress:
   Interface=0x3E9926D4, Progress Indication=NOT END TO END ISDN(1), Signal Indication=INTERCEPT(2),
   Cause Value=127
008298: Mar 1 17:10:04.124: //62896/2E5FCA3F803E/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
008299: Mar 1 17:10:04.124: //62895/2E5FCA3F803E/CCAPI/ccCallCutProgress:
   Progress Indication=NOT END TO END ISDN(1), Signal Indication=INTERCEPT(2), Cause Value=127
   Voice Call Send Alert=FALSE, Call Entry(Alert Sent=FALSE)
008300: Mar 1 17:10:04.124: //62895/2E5FCA3F803E/CCAPI/ccCallCutProgress:
008301: Mar 1 17:10:04.124: //62895/2E5FCA3F803E/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0xF5AF, gcid=2E606667-DF3111E5-8041E9BB-423D3151, tag=0x0)
008302: Mar 1 17:10:04.124: //62896/2E5FCA3F803E/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0xF5B0, gcid=2E606667-DF3111E5-8041E9BB-423D3151, tag=0x0)
008303: Mar 1 17:10:04.124: //62895/2E5FCA3F803E/CCAPI/ccConferenceCreate:
   Conference Id=0xFFFFFFFF, Call Id1=62895, Call Id2=62896, Tag=0x0
008304: Mar 1 17:10:04.128: //62895/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008305: Mar 1 17:10:04.128: cc_api_get_xcode_stream : 4982
008306: Mar 1 17:10:04.128: //62895/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008307: Mar 1 17:10:04.128: cc_api_get_xcode_stream : 4982
008308: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/cc_api_bridge_done:
   Conference Id=0x877, Source Interface=0x40977FA8, Source Call Id=62895,
   Destination Call Id=62896, Disposition=0x0, Tag=0x0
008309: Mar 1 17:10:04.128: //62896/2E5FCA3F803E/CCAPI/cc_api_bridge_done:
   Conference Id=0x877, Source Interface=0x3E9926D4, Source Call Id=62896,
   Destination Call Id=62895, Disposition=0x0, Tag=0xFFFFFFFF
008310: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/cc_generic_bridge_done:
008311: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x877, Destination Call Id=62896)
008312: Mar 1 17:10:04.128: //62896/2E5FCA3F803E/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x877, Destination Call Id=62895)
008313: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/ccConferenceCreate:
008314: Mar 1 17:10:04.128: confID:0x877; callEntry1 callID1:0xF5AF, type:3; callEntry2 callID2:0xF5B0, type:6
008315: Mar 1 17:10:04.128: //62896/2E5FCA3F803E/CCAPI/cc_api_caps_ind:
   Destination Interface=0x40977FA8, Destination Call Id=62895, Source Call Id=62896,
008316: Mar 1 17:10:04.128: //62896/2E5FCA3F803E/CCAPI/cc_api_caps_ind:
008317: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3E9926D4, Destination Call Id=62896, Source Call Id=62895,
008318: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/cc_api_caps_ind:
008319: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=8134)
008320: Mar 1 17:10:04.128: //62896/2E5FCA3F803E/CCAPI/cc_api_caps_ack:
008321: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=62895
008322: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/ccCallNotify:
008323: Mar 1 17:10:04.128: //62895/2E5FCA3F803E/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x877, Call Id1=62895, Call Id2=62896
008324: Mar 1 17:10:04.132: //62896/2E5FCA3F803E/CCAPI/cc_api_voice_mode_event:
   Call Id=62896
008325: Mar 1 17:10:04.132: //62896/2E5FCA3F803E/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x3F2AA3F8)
008326: Mar 1 17:10:13.376: //62895/2E5FCA3F803E/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x40977FA8, Call Id=62895
008327: Mar 1 17:10:13.376: //62895/2E5FCA3F803E/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
008328: Mar 1 17:10:13.376: //62895/2E5FCA3F803E/CCAPI/ccConferenceDestroy:
   Conference Id=0x877, Tag=0x0
008329: Mar 1 17:10:13.376: //62895/2E5FCA3F803E/CCAPI/ccConferenceDestroy:
008330: Mar 1 17:10:13.376: confID:0x877; callEntry1 callID1:0xF5AF, type:3; callEntry2 callID2:0xF5B0, type:6
008331: Mar 1 17:10:13.376: //62895/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008332: Mar 1 17:10:13.376: cc_api_get_xcode_stream : 4982
008333: Mar 1 17:10:13.376: //62896/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008334: Mar 1 17:10:13.376: cc_api_get_xcode_stream : 4982
008335: Mar 1 17:10:13.376: //62895/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008336: Mar 1 17:10:13.376: cc_api_get_xcode_stream : 4982
008337: Mar 1 17:10:13.376: //62895/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
008338: Mar 1 17:10:13.376: cc_api_get_xcode_stream : 4982
008339: Mar 1 17:10:13.376: //62895/2E5FCA3F803E/CCAPI/cc_api_bridge_drop_done:
008340: Mar 1 17:10:13.376: //62896/2E5FCA3F803E/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=62895, Disposition=0x0, Tag=0x0
008341: Mar 1 17:10:13.376: //62895/2E5FCA3F803E/CCAPI/cc_generic_bridge_done:
008342: Mar 1 17:10:13.376: //62896/2E5FCA3F803E/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
008343: Mar 1 17:10:13.376: //62896/2E5FCA3F803E/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
008344: Mar 1 17:10:13.376: //62896/2E5FCA3F803E/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
008345: Mar 1 17:10:13.376: //62895/2E5FCA3F803E/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
008346: Mar 1 17:10:13.376: //62895/2E5FCA3F803E/CCAPI/ccCallDisconnect:
008347: Mar 1 17:10:13.392: //62895/2E5FCA3F803E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x40977FA8, Tag=0x0, Call Id=62895,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
008348: Mar 1 17:10:13.392: //62895/2E5FCA3F803E/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
008349: Mar 1 17:10:13.392: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
008350: Mar 1 17:10:13.392: :cc_free_feature_vsa freeing 21CF53A0
008351: Mar 1 17:10:13.392: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
008352: Mar 1 17:10:13.392: vsacount in free is 6
008353: Mar 1 17:10:13.396: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x035A
       Cause i = 0x8090 - Normal call clearing
008354: Mar 1 17:10:13.676: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x835A
008355: Mar 1 17:10:13.676: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x035A
008356: Mar 1 17:10:13.676: //62896/2E5FCA3F803E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3E9926D4, Tag=0x0, Call Id=62896,
008357: Mar 1 17:10:13.676: //62896/2E5FCA3F803E/CCAPI/cc_api_call_disconnect_done:
008358: Mar 1 17:10:13.676: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
008359: Mar 1 17:10:13.676: :cc_free_feature_vsa freeing 21CF6440
008360: Mar 1 17:10:13.676: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
008361: Mar 1 17:10:13.676: vsacount in free is 5
008362: Mar 1 17:10:20.876: //62839/B9B65DF08291/CCAPI/ccGenerateToneInfo:
008363: Mar 1 17:10:20.880: //62886/B9B65DF08291/CCAPI/cc_api_call_feature:
008364: Mar 1 17:10:20.888: //62886/B9B65DF08291/CCAPI/cc_api_call_facility:
008365: Mar 1 17:10:20.888: //62886/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
008366: Mar 1 17:10:20.888: call_info mainst_callID:0xF5A6, peer_callID:0xF577, confID:0x876, spi_type:4, media_flo_thru:1,num_streams:1, swmtpmsp_present:0
008367: Mar 1 17:10:20.888: //62886/xxxxxxxxxxxx/CCAPI/cc_api_ha_call_active_notify:
008368: Mar 1 17:10:20.888:   stream[0]: callid:0xF5A6, media_passthrough:0
Dennis Sutphin Jr.
Here is your error message:
and its received from your provider
check your provider what the expect as the called number in, and what they expect you to send, did they tell you when you spoke to them?
Please remember to rate useful posts, by clicking on the stars below.
6 Replies 6
Dennis Mink
can you post the config and the dialpeers that are getting hit for international outbound calls on that router.
cheers
here you go.
Dennis Sutphin Jr.
sorry we match dial-peer 220
customer is getting call can not be completed as dialed.
Dennis Sutphin Jr.
no there answer was it i not our issue check with your implementer. They are long gone and i am trying to provide the end customer support. I will go to the telco again tomorrow and ask them what they are looking for us to sent to them as our called number.. correct
Dennis Sutphin Jr.
Please check if you have binded the correct interface with H323
