Unity 8.5.1 Replication error
kalbasha0
I'm getting replication status error message # 3 between our Unity pub and Sub servers
I have run the following form the pub
Utils dbreplication status
Copy current replication file and receive the error
Pub status is 2 active local
Sub status is 3 active connected
I need assistance to resolve the replication issue
Current environment
Unity 8.5.1.10000-206
Thx
6 Replies 6
David Hailey
A database status of 3 translates to the following state:
3 (Broken) — Replication failed during setup and is not working
For this state, the first thing to do is to reboot the Subscriber server and see if the replication issue is resolved.  Have you done this yet?
Hailey
Please rate helpful posts!
Yes i did , however no luck
Check out the following guide...it refers to CUCM but the procedures for troubleshooting the DB are the same:
https://supportforums.cisco.com/docs/DOC-8194
I tried everything with no luck . Still the same error message 3
If you have performed a repair as well as a reset and verified host name and other settings as per the document and replication is still broken, then it would be in your best interest to open a TAC case so that you can receive some hands-on assistance in troubleshooting and resolving the issue.
Hailey
I'm guessing when you say you tried everything, you have already verified DNS? [if your installation is using DNS.]
