08-09-2016 11:00 PM - edited 03-17-2019 07:47 AM
Hello All,
Could you please any one advise, VIC2-2BRI-NT/TE will have capability to support DSUs (mean U interface Features) ?
mean 1-Port HWIC-1B-U is designed to support U interface with single pair wire (RJ-48C connector) , but same line can be used to connect with VIC2-2BRI-NT/TE cards?
Thanks in advance!!
best regards,
Naveen
08-10-2016 02:55 AM
Hi Naveen,
To configure the VIC2-2BRI-NT/TE as an N/T device (U interface) use below command
"isdn layer1-emulate network"
MK
08-10-2016 03:00 AM
Hi Mohammed,
Thanks a lot your advise & support.
The cabling is only one pair, could you please advise i need to use VIC2-2BRI-NT/TE - RJ 48 pin 4 & 5. k.
best regards,
Naveen
