VM Lamp won't turn on
mmoss80
Recently we went from 4 digit extensions to 5 digit extensions. When all was said and done the voicemail lamp stopped turning on. I can see in unity that the lamp is flagged as on, but I've had no luck figuring out why it's not working. So far I'm done a master reset, changed out phones, manually tried flipping it on using 5050 to no avail. The phones are 8800 series and it seems like the problem is pretty random only affecting some phones. The VM icon shows on the screen, but no red lamp on the handset.
I would guess that you changed the DNs in CUCM and the Extension in CUC to the 5-digit extension. But the field that CUC uses to signal MWI back to CUCM is listed under "Message Waiting Indicators" in the User account. Have those fields also been edited to 5-digits?
Maren
