You will need to change the gateway configuration in CUCM. You will need to select the 3900 router model and then configure it for mgcp..
On the gateway itself, you can just configure the new gateway with the parameters of the old one. The only thing to look out for is the vwic ports which may have changed.
Please rate all useful posts
