02-22-2018 01:42 AM - edited 03-17-2019 12:16 PM
Hi Cisco community,
scenario: Phone A --> CUCM --> Phone B | Call from Phone A to Phone B
We assue early offer is used.
Phone A places the call and sends the INVITE with its SDP. In that SDP there is also a field that distiguishes the m= audio with a port on which the phone is listening to at a later stage, when the RTP stream is up and running. QUESTION: From which port range does the phone choose its port? The same question applies for Phone B in the 200 OK message.
I read that CUCM uses RTP ports in the range of 16384 - 32767. When do these ports come into play?
Moreover did I see, that I could also specify a start and stop port range in the SIP profile.
It would be great, if someone could explain these topics to me. Thank you in advance.
Solved! Go to Solution.
02-22-2018 06:00 AM
My apologies, those cannot be found in service parameters but SIP profile as you mention. Yes, you can change them, but why would you want to do that?
02-22-2018 05:45 AM
Yes, by default phone will request to use UDP port from 16384 - 32767 range unless you change it in CUCM service parameters. Keep in mind these are ports used by Cisco and other endpoints or telcos will use other ports. Newer IOS-XE versions also changed the range, so you might see different ports negotiated by CUBEs/GWs.
02-22-2018 05:51 AM
Hi Chris,
thank you for your reply. I couldn't find the respective settings in the service parameters. Could I also change it in the SIP-Profile? There also seems to be an option to tweak it.
02-22-2018 06:00 AM
02-22-2018 06:06 AM
I don't want to change them. I was just curious as to where the phones get those information from.
That basically means, that the phones store these information and use them when applicable. Correct?
I also wanted to know, when CUCM uses the dynamic RTP ports 16384 - 32767 / UDP. As seen here:
Table 7 Signaling, Media, and Other Communication Between Gateways and Cisco Unified Communications Manager
Maybe if the CUCM is being used as a MTP?
Thank you.
