12-03-2023 04:22 AM
Dear Guru,
We have a lot of agents has short calls and we need to know Who ended the call from agent side or from the customer side ?
Cisco CUCM 12.5
Cisco UCCX 12.5
Standard License
12-03-2023 04:28 AM
Look at the SDL logs in CM. This is visible in them. Possibly there are also some report(s) in CIUC where you can see this.
12-03-2023 04:33 AM
What's the advantages of SDI here ?
Kindly clarify ?
12-03-2023 04:39 AM
The SDL logs contains information about all calls, including whom ended it.
12-03-2023 08:46 AM
To add a tip to what @Roger Kallberg suggested also in CDR , searching for origCallTerminationOnBehalfOf you can find who termiated a call. If a phone (Agent) terminates a call, the value of that parameter is 12.
Carlo
12-04-2023 07:45 AM
2Ring Gadgets for Cisco Finesse offers an interaction history gadget that's available inside of Cisco Finesse, and it shows this information to supervisors - along with details of each interaction and agent state history. Please see a screenshot below + more information is available at these two links:
- https://www.2ring.com/products-manager/gadgets-for-cisco-finesse/features/#agent-interaction-history
- https://www.2ring.com/products-manager/gadgets-for-cisco-finesse/features/#agent-state-trace
To learn more, please request a demo at www.2Ring.com/Webex Thank you.
