Why should you police VoIP to 128kpbs on an ingress port?
wchatcher
In all of the examples I have looked at in the QoS SRND and the Medianet Campus QoS Design 4.0 guide they show inbound VoIP being policed at 128kbps and inbound signaling being policed at 32kbps on the ingress switch port.  None of the examples really say why they are policing at this rate.  What are the risks/effects should you police inbound VoIP at say 256kbps?
C3750-E(config)#policy-map PER-PORT-POLICING
C3750-E(config-pmap)# class VVLAN-VOIP
C3750-E(config-pmap-c)#  set dscp ef
C3750-E(config-pmap-c)#  police 128k 8000 exceed-action drop
 ! VoIP is marked EF and policed to drop at 128 kbps
C3750-E(config-pmap-c)# class VVLAN-SIGNALING
C3750-E(config-pmap-c)#  set dscp cs3
C3750-E(config-pmap-c)#  police 32k 8000 exceed-action drop
 ! (VVLAN) Signaling is marked CS3 and policed to drop at 32 kbps
Chris Deren
256kbps is perfectly fine, the idea is to keep it low which 256 on LAN is very low to prevent any worm, virus, etc from emulating voice traffic. In fact I use 256kpbs on my deployments as with built in bridge with G711 you reach 128kbps of payload.
HTH,
Chris
Chris Deren
HTH,
Chris
Chris,
Sorry for not replying before now.  That helped alot, thank you for your responce.
Bill Hatcher
NP, thank you for nice rating.
Chris
