Showing results forĀ
Search instead forĀ
Did you mean:Ā
HCS-LocalBreakinBreakOut/central BreakinbreakOut Troubleshooting
SAM ANANDARAJAH
Hi ,
Have an issue where , in some countries, you have to use the LocalBreakin-out and some counties Central Breakinout..
troubleshooting of Signalling is easy enough from SDL on the Uc-apps , but the biggest issue is with Media ?
in some-case  we could run deubgs on the ASR - but in some cases the media doesnot flow through the ASR we controll, so only common point would be UC-APPS .
Is there any way to check from UC-apps , to get either run a SQL or another methods of  troubleshooting Media from either RTMT or CLI ?
Sam
0 Replies 0
