IPSEC Policy Configuration
marwa.ads
I want to enable /disable the policy at IPSEC Policy Configuration , also i want to delete the whole configuration.
can i do this using axl? how can i do it?
Geevarghese Cheria
Hi Marwa,
     AXL is an abstraction layer for the Cisco Unified Communications Manager  configuration database. It is a
webservice, Nearly everything you can do with the ccmadmin webpages you can also do with AXL automatically.
That being said since IPSEC policy configuration is not part of CUCM i think its not possible using AXL.
Please refer - PCNetzwerke.de - Using Cisco Unified Communications Manager AXL API
and Administrative XML API for further details.
Thanks and Regards,
Geevarghese
Hi Geevarghese,
Thanks for your answer.
Do you know how i get the IPSEC policy Configuration? can it be done using serviceability?
Marwa
Hi Marwa,
I would request you to refer this url IPsec Provisioning
for related information.
Thanks and Regards,
Geevarghese
