12-04-2014 01:54 AM
I want to automatize some operations and for that I need to get the mapping between the AXL field and the translated fields in Cisco GUI.
For example, on the device mobility info, for the field "subNetMaskSz" I need to get "Subnet Mask (bits size)".
Is there a simple way to get the translation ?
Fabien
12-04-2014 10:13 AM
Unfortunately there is not any document that directly maps AXL elements to GUI fields.
12-10-2014 02:05 AM
Thank you for the answer. How does the translations are made in the CUCM ? Is there somewhere a properties file or something like that ?
12-10-2014 03:34 PM
Unless I misunderstand your question:
- UCM configuration info is stored in the onboard database
- The UCM admin web UI uses hand-written code and SQL queries to read/write from the DB
- The AXL API uses a different set of hand-written code and SQL queries to read/write from the DB
The design intent is for the web UI and AXL to reasonably line-up (for the most part) with regards to the types of objects, operations, parameters, etc., available; however there is no distinct or directly documented mapping between the two interfaces.
12-12-2014 08:08 AM
Thanks for the answer.
In fact the question is more "how translations are stored in the CUCM server?". Is there a properties file that contains them? Are they stored in the database? The idea is to be able to access using a java request if I know the key.
Fabien
12-12-2014 09:29 AM
Are you referring to language localization of the UC Manager admin web pages..?
Are you looking to get a list of 'locales' available on the system for phones?
12-16-2014 07:56 AM
I mean on the UC Manager admin web page. Are the pages translated in hard or the translations stored somewhere that I can retrieve them ?
12-16-2014 01:02 PM
Unfortunately I'm not aware of how the UCM admin UI locales are implemented/stored, and this does not appear to be documented. Some other localized parts of the system - for example phone locales - utilize files stored in the UCM TFTP system. Browsing the TFTP system (in UCM OS Administration pages) may turn up something interesting...
Can you describe the use-case/requirement you are trying to satisfy?
