LineAppearanceAssociationForPresence - changes in behavior between CUCM 10.5 and 11.5
stephan.steiner
I'm currently running my updated unit tests to test my own AXL library. My unit tests were written for 10.5 initially - and they all passed prior to the upgrade. Now there seems to be a behavior change in the endUser object between 10.5 and 11.5
In 10.5, when you add a user, you had to manually assign the LineAppearanceAssociationForPresence after creating the user with the right controlled devices and device profiles. In 11.5 however, if you create the user with controlled devices / associated device profiles, and you extract that user again, you'll have the LineAppearanceAssociationForPresence field filled with the lines that belong to the controlled devices / device profiles.
Is this correct behavior? Absent a documentation that lists changes in 11.5 I can't be sure
0 Replies 0
